New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #351
I'm sure it won't affect anything but why is the pintle skewed?
It looks like the same hitch my truck has. It’s free to rotate 360 degrees. It’s kinda annoying because if the trailer is a little to low it will flip the hitch sideways.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #352
Well, the 7500 4x4 is back and in service. Truck would not start. Turns out 2 of the 3 batteries I installed just 10 months ago were defective!! I was given free replacements and decided to add a new 3rd battery as well.
Still working the bugs out on several electrical gremlins. One is headlights not working. Other is a parking light on the front fender not working.
Fixed those 2 this morning. Previous owner mounted a switch on the dash. I didn’t know what the switch was for (no label). My headlights were not working. After exhaustively trying to track down the issue, here it was the unlabeled switch :mad: Turns out the switch is used to turn headlights “off” and the old plow lights “on”. OK, now I’m done clanging my head off the wall trying to fix that one.
The parking light was a wire that was chewed about 90% through. There was maybe one corroded strand left. Fairly easy fix.
This truck was equipped with mirror heat on all 4 mirror heads. It doesn’t work. That’s my next electrical gremlin.
Bad pictures, but here it is as of now. I really need a front grill and 4 new steel wheels.
Ordering tow hooks and mirror mount beacons.
Truck build sheet says 8.25 x 22.5 wheel. Looks like a 9” wheel to me. Maybe it’s the rust patina throwing me off….
Truck is going to look weird with a “no-sale” green cab, faded black dump bed and new white wheels. I think that’s why the previous owner painted wheels black??
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #355
I have a grill for an International that made it thru a wreck by just getting popped off. Put grill in upper sleeper and told the body shop...but they put a new one on.
Could use a better picture of yours to see if they match. The area in question is the lower corners of grill where they meet the headlights.
David from jax
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #356
Never mind, they don't match.
David from jax
Note scre hole/mounting tab locations. Mines a 7500. There’s a myriad of different grilles. International has such a bad parts system.
No wonder Volkswagen bought them out.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #358
I went out and grabbed a picture of the grill on truck and got approached by the wild animals we feed every day. Not much wild about these wild animals!
Wife would love for the grill to have matched, as She isn't much of a collector!
David from jax
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #359
You going to try heat on the flares to darken them up?
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A58375)
UNUSED CFG...
UNUSED CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Toro Sand Pro (A56859)
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
LOT: Steel File Cabinets, Steel Cabinets, Primo Electric Water Cooler (A59076)
LOT: Steel File...
