Ford 2110 (1986 Japanese model) hard starting when cold
   / Ford 2110 (1986 Japanese model) hard starting when cold #1
MadJack
Litchfield, Maine
86 Ford 2110 4x4
The glow plug heater helps a little but it still only starts on 2 cylinders, and only when it feels like it. (black smoke when it tries to start)
I was told today it may be a couple dead glow plugs.
It started pretty well August/September, and always runs well and smooth once started.
So what's your thoughts on this being a glow plug issue?
Thanks
   / Ford 2110 (1986 Japanese model) hard starting when cold #2
On a tractor that old I would bet it has some dead glow plugs.
You can test them with an ohm meter.
That said glow plugs (SBA185366060) typically don’t cost too much, so I‘d replace all of them.
SBA185366060HVACSTAR 3pcs Glow Plug SBA185366060 for New Holland Tractor https://a.co/d/dc0O3xI
   / Ford 2110 (1986 Japanese model) hard starting when cold #3
Use a voltmeter to see if you're even getting voltage to the glow plugs. If you're getting power check to see if they're open or burned out. You should also check your air filter and air path to the intake manifold.
SBA185366060HVACSTAR 3pcs Glow Plug SBA185366060 for New Holland Tractor Amazon.com
Thanks DS80! That part number comes up at $9 each and is listed for over 70 machines. I ordered 4 and should have them Friday or Monday.
I am working through lack-of-maintainence issues from the previous owner(s), and $36 is a cheap check-off from my list.
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
PIPE TRAILER (HOMEMADE NON TITLED) 28FT (A52472)
PIPE TRAILER...
1269 (A50490)
1269 (A50490)
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
