James Webb Space Telescope begins historic mission
   / James Webb Space Telescope begins historic mission #351
FUNKY!
   / James Webb Space Telescope begins historic mission #352
A New Frontier: NASA’s Webb Space Telescope Confirms Existence of Earth-Sized Rocky Exoplanet!​
AstronomyExoplanetJames Webb Space TelescopeNASA Goddard Space Flight CenterPopularSpace Telescope Science Institute
By Space Telescope Science Institute January 17, 2023
Exoplanet LHS 475 b and Its Star
This illustration reflects that exoplanet LHS 475 b is rocky and almost precisely the same size as Earth based on new evidence from NASA’s James Webb Space Telescope. The planet is only a few hundred degrees warmer than our home planet. The planet whips around its star in just two days, far faster than any planet in the solar system, but its red dwarf star is less than half the temperature of the Sun. Researchers will follow up this summer with another observation with Webb, which they hope will allow them to definitively conclude if the planet has an atmosphere. LHS 475 b is relatively close, 41 light-years away, in the constellation Octans. Credit: NASA, ESA, CSA, Leah Hustak (STScI)
Researchers using NASA’s James Webb Space Telescope have formally embarked on a new frontier: Identifying and analyzing rocky exoplanets that orbit red dwarf stars. A team led by Kevin Stevenson and Jacob Lustig-Yaeger, both of the Johns Hopkins University Applied Physics Laboratory in Laurel, Maryland, confirmed that LHS 475 b not only exists, but it is a small, rocky planet that is almost exactly the same size as Earth. Before Webb, researchers typically targeted planets that are larger than Jupiter, which is 11 times wider than Earth. This will inevitably be the first of many discoveries Webb data will help researchers make as they continue exploring planets elsewhere in our Milky Way galaxy.
Using NASA’s James Webb Space Telescope, researchers confirmed an exoplanet, a planet that orbits another star, for the first time. Formally classified as LHS 475 b, the planet is almost exactly the same size as our own, clocking in at 99% of Earth’s diameter. The research team is led by Kevin Stevenson and Jacob Lustig-Yaeger, both of the Johns Hopkins University Applied Physics Laboratory in Laurel, Maryland.
   / James Webb Space Telescope begins historic mission #353
I got a news feed about some problem with the webb amd now I can't find it. Did you see it? if so, please post it.
   / James Webb Space Telescope begins historic mission #354
   / James Webb Space Telescope begins historic mission #356
Niel Tyson speaking about new discovers found with the Webb. What you find when you are home and ill. 😂 Its quite good and he discribes why new things are being found.
That's a very interesting, understandable video. Nice find, Feel better.
   / James Webb Space Telescope begins historic mission #357
Interesting discovers with the Hubble, then Webb telescopes. Theories may need to be adjusted.
CATERPILLAR 259D3 SKID STEER (A52707)
CATERPILLAR 259D3...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2015 INTERNATIONAL LF687 SLEEPER (A56138)
2015 INTERNATIONAL...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
Utility Trailer (A52377)
Utility Trailer...
