Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #22,942
I fixed my steering and was able to do a little work today, good to have a working tractor this time of year!
   / Tractors and wood! Show your pics #22,943
We did use mini-split heat a lot in November/December whenever the ambient temps were up above 40f (quite a bit) which delayed our firewood consumption in the early season.
Normally, I have an electric bill between 70-80 bucks. For the first time since I got it, I used the mini split 24/7 to heat a room for 3 days and my bill was $128. It was set for 70* and temps were in the mid to high 30's
I thought these things were supposed to be efficient and save money?
It was cheaper to run the boiler for that length of time.
Was wondering if they're all like that.
   / Tractors and wood! Show your pics #22,945
$130 to heat with a mini split for 3 days couldn’t be accurate. The circuit ran to the mini split couldn’t even supply enough current at 100 percent load for the entire 3 days to cost $130. The efficiency of a mini split or any heat pump reduces in cold weather since it has to use electric resistance heating but it’s still not that costly.
   / Tractors and wood! Show your pics #22,946
Any heat pump (mini splits are heat pumps) falls off efficiency below outside air temps in the high 30s, depending on brand. I am in a marine climate, so we have a lot of days in the 40s and 50s outside. That is the sweet spot for a heat pump in my opinion. If you run them as a heat pump below the high 30s or even low to mid 40s (again depending on brand) they have to go through a defrost cycle for the outdoor unit at which time they are in air conditioning mode and have to reheat the air with resistance heat just to get back to not cooling the house. Some (mine does) have the ability to go to full re$i$tance heat. I shut mine off below 48 or so outside and burn firewood only.
   / Tractors and wood! Show your pics #22,951
No
That was my total bill.
The mini split added another 40 or 50 bucks.
   / Tractors and wood! Show your pics #22,953
It takes 3 of his to make 1 of mine. :D
We have bigger trees, although nothing like what you have out there. However, balsam fir like what he is cutting is a short lived tree, only lasting about 70 years. When it stays in the understory like mine apparently did for the first half of it's life it doesn't get very big. What I'm cutting is 6-10 inches on the butt, and rarely longer than 30 feet to a 4 inch top. I also usually leave 2-16 feet in the woods because it's rotten.
What Gorson is cutting is nice as far as fir goes; it is of good size for the species, and sound.
   / Tractors and wood! Show your pics #22,956
More than 3 I would say. Our fir aren't big trees by any means. They average 12" to 16" at the butt. Then there is butt rot due to a fungus in our soil that I have to cut off. This one is typical in size and the amount of rot I have to cut. The saw has a 16" bar.
I do have the occasional bigger tree. The bigger ones, if they are older, have more rot usually. This one is 24" and there was 12' of rot before I found good wood.
gg
   / Tractors and wood! Show your pics #22,958
Glanced at Mr. Sawyer Rob's first picture and my first thought was that big old Oak was tangled in a power line!
Hmmm... "That could be sketchy to take down..."
Then realized he was just tying off his tractor to keep it from wandering away!
   / Tractors and wood! Show your pics #22,960
I had my winch line hooked up high and winched it over.
I wanted to make sure it would fall toward me, into the opening, and plus, there's a fence on the back side that I didn't want to have to fix. lol
I've already cut two big loads off that tree,
And split it up, by rolling them onto the splitters beam,
and splitting them up,
They make a LOT of excellent firewood! I'll be back on that job when it warms back up, as there's still a decent log or two out there,
SR
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
International S1900 (A61306)
International...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
159115 (A60430)
159115 (A60430)
Toro Sand Pro (A56859)
