Hello, looking for Service & Shop Repair Manual's for a Ford New Holland: 1991 TRACTOR - UP30554, MODEL - AP413A
   / Hello, looking for Service & Shop Repair Manual's for a Ford New Holland: 1991 TRACTOR - UP30554, MODEL - AP413A #1
finom1
John Deer LT155
Hello,
Could you please help us find what we are looking for?
We are looking for a service/shop repair service manual to work on the Clutch assembly that is stuck and will not release. Could you please provide us with what manual that will be needed to service the clutch assembly?
We have a Ford New Holland: 1991 TRACTOR - UP30554, MODEL - AP413A
ENGINE - N844 – 17894
UNIT – CYJ13B
Thank you for any help!!!​
   / Hello, looking for Service & Shop Repair Manual's for a Ford New Holland: 1991 TRACTOR - UP30554, MODEL - AP413A #2
I think this IT manual FO-46 will work for you if the tractor is a model 1920.
   / Hello, looking for Service & Shop Repair Manual's for a Ford New Holland: 1991 TRACTOR - UP30554, MODEL - AP413A #3
Your model number AP413A translates as follows:
AP4 = Ford 1920
1 = Diesel engine
3 = Live PTO, 540 rpm
A = 4x1 four speed manual transmission.
kirkawilson
Thank you so much for the quick response and that translation!!! This was very helpful, thanks again.
We have hope now:)
@kirkawilson
Here is a picture of the name plate, just to make sure we have the correct manual!!!
   / Hello, looking for Service & Shop Repair Manual's for a Ford New Holland: 1991 TRACTOR - UP30554, MODEL - AP413A #6
The serial number matches up with a 1991-92 number from TractorData.com Ford 1920 tractor information
If it has a loader, the clutch housing access hole is located underneath one of the loader mounting plates..can't remember which side..and you need to remove the loader to see it. You might be able to adjust the clutch through the access hole. Otherwise, the tractor must be split to replace the 2-stage clutch (1st stage for drive train, 2nd stage for PTO).
   / Hello, looking for Service & Shop Repair Manual's for a Ford New Holland: 1991 TRACTOR - UP30554, MODEL - AP413A #8
Looks like a pretty good deal. I only have the IT service manual and use it regularly. The other three manuals might come in handy when you need more details.
BTW, I had the clutch replaced in my NH1920 about 12 years ago by a 'tractor guy'. He offered either a rebuilt clutch or a new clutch for about $200 more. I went with the new clutch because most of the replacement cost is labor anyway. The new clutch has worked perfectly and I hope to never replace it again.
kirkawilson
You have been extremely helpful. We are doing this for the first time and you have helped us greatly.
Have a Blessed day!!!
71052 (A49346)
71052 (A49346)
Landoll (A50657)
Landoll (A50657)
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2016 VOLVO VHD TRI-AXLE DUMP TRUCK (A51222)
2016 VOLVO VHD...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
