If you have a barbed wire fence, then you must have this stretcher..
   / If you have a barbed wire fence, then you must have this stretcher.. #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
This is a goldenrod 415 fence stretcher splicer.
It has 3 grabbers which is very convenience.
   / If you have a barbed wire fence, then you must have this stretcher.. #2
I've got the 2 grabber version, two of them, wore one out I used it so much.
I can't figure out why the third grabber helps any more than two. I use barbwire and wooden posts.
Answer is not much different but more convenient than 2 grabbers in my experience.😂😂
   / If you have a barbed wire fence, then you must have this stretcher.. #4
I have a mile and a half of barbed wire around my property. Four strands of Red Shank - Ever Sharp and 670 T-145 steel posts. I used my Hi Lift jack - chained to my tractor - at first. Then my neighbor loaned me his stretcher.
Made the job much easier.
HOWEVER - I feel so blessed every day I think about all this fence. I did it all - 42 years ago when we first moved down from Alaska.
Must have done a pretty good job. It still stands - tough, straight and true.
   / If you have a barbed wire fence, then you must have this stretcher.. #5
@jkk04 +1 here! I love mine. I find that the three jaw version is especially convenient for taking up long runs of slack, and I use all three jaws for mid-run splicing.
Mostly, I like that the wire is rigidly locked in when it is under tension. In use, I keep the sold side of the jaws toward me, just in case. I grew up with rope and pulley tensioners that in my hands were more prone to releasing when I wasn't ready for them. I still use the rope and pulley versions for complex repairs, but 95% of the time I use the Goldenrod stretcher for my wire work. (4 & 5 strand barb wire)
All the best,
Peter
   / If you have a barbed wire fence, then you must have this stretcher.. #6
That type stretcher works well but since I already have a come along in all my tool boxes this costs less and saves space in tool boxes.
All the best,
Peter
Also, it is made in the USA. Last forever😊😊
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2017 Nissan Titan Crew Cab Pickup Truck (A51692)
2017 Nissan Titan...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
