1710 hydraulic rear remote adapter plate
   / 1710 hydraulic rear remote adapter plate #1
John 1219
Ford 1710 1986 4wd
I see a post of a person making these adapter kits. I've tried to contact him thru pm but no luck would anyone happen to have a good email for him?
   / 1710 hydraulic rear remote adapter plate #2
And you need this adapter because...?
I have a wood splitter that's hydraulic driven. I need the remote lines to run it
   / 1710 hydraulic rear remote adapter plate #4
If your tractor has standard hydraulics it should look something like this. If you have item #48 in this diagram then you don't need any adapter plate. You already have what's required. All you need is a proper valve and some plumbing.
Hello Harry I don't see a diagram to go by. If your talking about the PB valve all I have is a cover plate on mine right under the seat on the right side
Hello Harry yes Ted sent me an email so I'm talking directly with him. Thank you for your help
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
John Deere M665 Zero Turn Mower (A55851)
John Deere M665...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
1999 Southwind Fleetwood 34N 34ft Class A Motorhome (A55853)
1999 Southwind...
2013 International WorkStar 7400 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
2014 Ram 1500 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 Crew...
