Stay away from Bad Boy Tractors
/ Stay away from Bad Boy Tractors #1
0Gt3X4N
Bad Boy 4025H
I'm just over 2 years in to owning a 4025H with BBH 400 backhoe and this things has been falling apart since month 2.
It started with little things like the fuel and temperature gauges no longer working. So, we never know how much fuel is in it or if it's overheating. All contact with the manufacturer falls on deaf ears and the service from the dealer is not great because they're always months behind.
The worst part is the poor build quality of these machines. The backhoe has snapped in half twice near the bucket and because it's been just over 2 years it's no longer covered under warranty. The backhoe has less than 10 hours of light duty work on it, mostly moving around black dirt on the ranch.
Because it snapped in half it's easy to see how thin the steel is and if you try to weld it, you realize that it's cheap Chinese stuff.
I regret purchasing this tractor and wish I would have gone with Deere or Kubota.
Look how thin the steel is!
Yeah, this ain't right.
/ Stay away from Bad Boy Tractors #2
That broken backhoe is discouraging, is that a stand alone with pump running off the PTO or plugs nto tractors hydraulic circuit? Next id try and figure out if there's a pressure relief, bypass valve that opens when circuits overloaded to help prevent it from happening again if you do get it fixed. I guess if there is I'd see if it's adjustable. My backwoods opinion. But I've owned a 3 point standalone BH that to my surprise and noob learning curve never broke.
/ Stay away from Bad Boy Tractors #4
Sorry to hear about your predicament. It's a painful lesson that hopefully others will learn from.
Sounds like Bad Boy cut corners to lower costs.
/ Stay away from Bad Boy Tractors #5
There's ways to check for metal fatigue, etc by examining break more closely by someone who has experience doing it. Preliminary, before getting someone else involved I'm sure these days you can find pictures online with different types and causes of fractures.
/ Stay away from Bad Boy Tractors #7
That bent pin says different.. Something doesnt look right.
  • Good Post
Reactions: D&D
/ Stay away from Bad Boy Tractors #8
Bad Boy are re-badged Branson (TYM). They are know for being very heavy duty. This sounds a lot like abuse.
I don’t think Branson makes the loaders or backhoes though.
/ Stay away from Bad Boy Tractors #9
I just looked on Tractor House; the loaders are definitely different suppliers. I didn't look for backhoes however, but I would assume the situation the same.
img.axd
img.axd
/ Stay away from Bad Boy Tractors #10
Looking at the left side of the stick looks like the steels folded over where it broke do you think you might have accidentally swung into something hard and immovable that initially dented stick that started fracture? right side looks like a clean break. What were you doing when it let go? Pulling stumps? Which from experience when I owned my 3point BH was very hard on it. The Oil got so hot it was expanding out the fill tube lol. Thinking back I still scratch my head and wonder how I didn't seriously break something. A 3 point BH is priced and built accordingly imo so folks can afford them and are definitely not as rugged as a cat 336 so should be used accordingly.
/ Stay away from Bad Boy Tractors #11
Ansung used to make the loaders and backhoes for Branson and a lot of other manufacturers. Not sure if that is still valid today.
As for the actual issue with the tractor, very minor in my opinion, even just unplugging and re-plug the connector behind the dashboard fixes that. If not, check and cleaning all the grounds also helps that.
It's interesting that a lot of people have 0 sense of troubleshooting or even checking stuff, even the most basic stuff, yet they sure are fast coming to the forums ranting and moaning about X brand just because they had some issues, most likely self inflicted.
I saw this poster post the same rant on Reddit. There, he keeps answering the comments most likely because he has a lot people patting his back for his rant for some reason. Over here, it's a different story and he probably won't come back here any time sooner.
/ Stay away from Bad Boy Tractors #12
Yeah I'm guilty of solution less ranting at times but why as an owner wouldn't you want to try and figure out why it broke in the first place to hopefully mitigate future problems? weather it's operator or manufacturing error? Having owned and used a 3pt bh im leaning towards operater unless tell tale signs in fractures or what the owner was truthfully doing with it tell me differently.
/ Stay away from Bad Boy Tractors #13
I dunno, my Branson has been rock solid. I frickin love this tractor. 90 minutes to till an acre? I’ll take it. I basically use it only for PTO work.
Now, I do care for it really well too
/ Stay away from Bad Boy Tractors #14
Also, not claiming that the Bad Boy versions are exactly the same as a Branson/TYM unit, because clearly they are not.
/ Stay away from Bad Boy Tractors #15
A low hr Branson was one of my first choices when I briefly thought of replacing one of my old tractors, Better half said I'd need to get rid of one of my old Kubotas first so I shut that idea down in a hurry lol. Drifting now, but anyone get attached to various physical objects with a ice? My wife definitely does not I'm a polar opposite, until occasionally and no matter what I throw at it in terms of time and parts, reliability issues let me down continuously. Or a grass snake pops out of a hoods xbracing and almost lands on my head lol
/ Stay away from Bad Boy Tractors #16
/ Stay away from Bad Boy Tractors #18
I know, bad boy blacked out the rims lol.
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
1000000 (A47477)
1000000 (A47477)
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED FUTURE 24"...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
