Troybuilt junior carb spring and governor linkage
   / Troybuilt junior carb spring and governor linkage #1
Tillernoob
Troybuilt junior tiller
I have an old troybuilt junior tiller hs40-55580k it’s from the 80s I believe it won’t engage the throttle when I pull the linkage cable I believe I’m missing a spring or linkage rod off the carb! Does anyone else own one and be willing to post a pick of there carb so I can see the carb springs and governor springs and how they are attached please and thank you
   / Troybuilt junior carb spring and governor linkage #2
That is exactly what I wanted thank you. Do you know what that piece is that attaches to the throttle and the top of the governor and where I might be able to order one
   / Troybuilt junior carb spring and governor linkage #4
I helped a friend with an old Troy Built. I have no idea if this helps but maybe you can zoom in and see if it helps.
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
MASSAGE CHAIR (A53843)
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
Utility Trailer (A52377)
Utility Trailer...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
