Kioti RX6620-RX7320 VS. Kubota M6060-M7060
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #21
HaHaHa! I can hear this cable being fixed now by the forum. :) Three point PM inbound. Thanks again,Glenn
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #22
I'm just a farmer who owns both Kubota and Kioti products. I have an L3400HST Kubota that's been bulletproof. Owned a L4400HST that was good too but sold it to buy a cab 60HP Kioti RX6010C with 200 hours on it. Based on experience the Kioti is not made and engineered nearly as well as the Kubota products.
I've fought the RX6010 running too hot even though I clean and wash out the radiator, checked hoses and water pump and made sure coolant mix is good. The tractor doesn't have the torque a 60HP tractor should have. Kioti rates their HP at 2600 RPM and the Kubota M6060 or M7060 rates theirs at 2400 RPM. The Kioiti uses a 148.5 cu.in. motor and Kubota uses a 203 cu.in. motor. Those extra cu.in. seem to make a big difference in torque, even though the HP numbers are similar.
Recently snapped a clutch cable at 280 hours shutting me down in the field, and of course the Kioti dealer doesn't have one in stock. If I had it to do all over again I'd opt to buy a Kubota M7060 and spend a little more, but have something that works all day.
I was considering buying a 6620, your post has made me to reconsider going with a Kubota.
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #23
2015 Thread.. A lot has changed
Cummins 6-Cylinder Diesel Engine with Transmission (A55852)
Cummins 6-Cylinder...
Mobile toilet with shower (A53424)
Mobile toilet with...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A57192)
2001 INTERNATIONAL...
Food Truck - 1999 Chevrolet Blue Bird School Bus and Turnkey Food Truck Business Package (A55314)
Food Truck - 1999...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
