Horizontal boring under driveway, costs etc.
   / Horizontal boring under driveway, costs etc. #11
If you don't have rocks or roots to contend with, jetting 30' is not difficult. I also do irrigation and we jet under driveways on a regular basis.
If you can get to the old pipe and you plan on using the same size pipe, using the old one to pull a new one is definitely an option. Have done this many times also.
In fact, you can usually pull one pipe size larger if needed without too much difficulty. The key is to make sure you pull slow, steady and smoothly.
If you decide to pull or jet a new pipe "over" the old pipe, using the old pipe for a guide, keep in mind that there is most likely a fitting in that run if it is longer than 20' and that the fitting needs to be able to fit into the the new pipe size.
Also, if you do jet a new pipe over the old, you will need to cap the old pipe on the end you are jetting from or the water will just run through the old pipe and not remove any dirt.
To test the ease of pulling a new pipe with the old, first expose about 5 or ten feet of the old pipe from the end you will feed the new pipe from. Then, expose the old pipe from the end you will pull from and attach whatever you plan to pull with to the old pipe (of course, you will have to cut the old pipe on both ends so it is free to move). By leaving 5 or ten feet expose you can do a test pull before connecting the new pipe to see if it will pull without damaging your new pipe and without causing the old one to "disappear" under the driveway.
If the old pipe will move when you pull on it, the new pipe will follow it right through. Even if the old pipe is Gal. you an use a threaded fitting to connect plastic to it and still use it to pull.
   / Horizontal boring under driveway, costs etc. #12
if you can not pull it via the old pipe, or jet it, there is a company called borzit, I have one of there tools you connect it to a heavy half inch drill, and turns sections of pipe with a water hose attached, and a bit on it so one can do it your self it is basically rock free, about $250 for the kit,
http://www.borzit.com/
How to Use
I have found it to work well in most situations,
   / Horizontal boring under driveway, costs etc. #13
I've attached coiled copper pipe to the existing and pulled it through with a truck and a helper... 22' was the longest pull... I did not want any joints so the reason for coiled copper...
Thanks for all the replies guys. I thought the thread had died.
The way I read TBN is click on New Posts and it seems often threads get posted to but don't turn up.
   / Horizontal boring under driveway, costs etc. #16
Thanks for the update. Did you just get it done, or did you do it 8 years ago and just remembered this thread?
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
Kubota BX2230D (A47384)
Kubota BX2230D...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
