Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,001
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've asked before about this and now, I have finally tried it.
My 1-year old water heater stopped. I presumed (from past expeience) that the calcium has built up at the bottom, buried my lower element and it shorted. Turns out that was NOT the case, but the calcium pile was VERYYYYYYYYYY close to the element.
I bought roughly 1 gallon of vinegar at Home Depot. They didn't have the higher percentage concentration.....the salesman (who in hindsight knew nothing) said they were the same.... they weren't but I digress.
Today I go get some 30% vinegar concetration. (4-gallons). I've added 2-gallons to the lowered water height. Interestingly, later on, I put my borescope down there via the upper element and you can see the bubbling as the calcium dissolves. My understanding is it turns into CO2 and water (but never was much of a chemist!)
The whole bottom is covered and is just below the lower element. I'm currently draining tank as I added the vinegar to maybe 1/2 tank of water. I'm letting it drain so I can put the 2-gallons in there with much less water, hoping it will be a higher ratio of vinegar to calcium.
What I'm wondering is, how much calcium might 2-gallons of 30% vinegar dissolve before it's worn out?
I might put it in prior to going to bed to force me to leave it alone for several hours and stop trying to peek!!! I've never done calcium removal this way. Last time I literally took tank off system, put on dolly and took outside, pulled anode rod out and flipped tank over so I could use hose to get much of it out the anode hole. I wasn't very able to get it out the lower element hole since it's above the bottom.
Curious if anyone has any tips on how to improve this process?? I might add, both original elements are coated with calcium. I bought two new ones. I'll put the new ones in and then soak these in vinegar to get all the crusted calcium off and then use these as a spare in event I blow an element at midnight on a weekend or holiday and need a quick spare.
