2018 Kubota L3901 wont start
   / 2018 Kubota L3901 wont start #1
bcribb
Member
Wilmington NC
Farm Trac 390 HST
I have a 2018 kubota L3901 that has lost power to the fuel pump. Does anyone kbow where the fuel pump gets its power from. Tractor wont start
   / 2018 Kubota L3901 wont start #2
I checked the electrical diagram, but just can't figure it out. It does not appear to be a dedicated circuit in the panel, so I guess you're going to have to start pulling and testing fuses.
I’ve tested all the fuses that I can find and they’re good. I’ve traced the wires to the end. One is a ground and the other goes to the two red buttons on the dash. Regen buttons. I’ve hot wired the fuel pump and it’s pumping fuel but something else must be keeping the fuel from getting to the injectors
The ecu came unplugged. It must have not been locked in. Tractor cranked right up. Now when I put it in gear it won’t go. Just had a new clutch installed last week.
MAKITA TABLE SAW (A53843)
MAKITA TABLE SAW...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
100 FUEL TANK (A53843)
