rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,579
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I know what you mean. We've got two work areas by the barn that belong to the birds until their young fledge each year. I encourage them with good nest boxes and such. Lots of swallows, too.On my loader they are typically reserved for bird nests since my loader stays parked quite a bit.
Down here, we keep yellow jacket nests in them.On my loader they are typically reserved for bird nests since my loader stays parked quite a bit.
Something I've never had to use. I keep both of them well greased (I have a 2 pin ATI on one tractor and a Kubota OEM on the other. What I do is, when I want to remove any SSQA implement, I tilt the loader arms back as far as I can and then the pins have no pressure on them and release with no effort.and a cheater pipe for the SSQA levers.
Yep, they need to be greased. Do you mean the bucket arms? I've never tried doing it that way. I always put it flat on the ground. Not sure that tilting back the long rock bucket would unload the pins.Something I've never had to use. I keep both of them well greased (I have a 2 pin ATI on one tractor and a Kubota OEM on the other. What I do is, when I want to remove any SSQA implement, I tilt the loader arms back as far as I can and then the pins have no pressure on them and release with no effort.
Far as the cross hole, never used it for anything.
