Repetitive clutch problems on my LS XU 5055
   / Repetitive clutch problems on my LS XU 5055 #1
DStoen
Melrose, Wi
LS5055
This is the third time that this tractor has been split to replace the clutch due to release (throw-out bearing seizures). I am wondering if any other tractor owners have experienced similar troubles? It only had 200 hrs. when the first one happened. Then 400hrs and now at 1109 hrs. Every time I find that the release bearing has seized up and I get that sudden sharp whine from the clutch area. As soon as it started I patked it and tore it apart just to find that the bearing in its seized state has already done some damage to the diagram on the pressure plate. I could use some advice on how to prevent this from reoccurring again! Thanks, Darrel
   / Repetitive clutch problems on my LS XU 5055 #2
Have you been checking the clutch pedal for free play frequently? After the first bearing change, I would be on top of that. The pedal should have about 1" of free play, which means the bearing shouldn't even be contacting the pressure plate.
   / Repetitive clutch problems on my LS XU 5055 #3
I agree and ask if you rest you foot on clutch pedal while operating the tractor? In days when cars and trucks primarily had standard transmissions it was common to see drivers using clutch pedal as a foot rest which resulted in short bearing life.
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2016 WESTERN STAR 4900 HYDRO VAC (A53843)
2016 WESTERN STAR...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
