2538 bucket lift cylinders...the stainless tubes
   / 2538 bucket lift cylinders...the stainless tubes #1
CDBUG
State O' Maine
Mahindra 2538
Been searching for a pair , one of mine is bent junk and the other is heading there. ..thanks
   / 2538 bucket lift cylinders...the stainless tubes #2
Try a local hydraulics shop. Just measure the length and width of the cylinder. They could probably give you some insight on where to go/buy it.
It might be less expensive to buy a used pair, even if you have to replace the seals. I think they're rated for almost 1000# each.
AD
Yes thanks, heading there tomorrow...not much to be found on the web for 2538's!
   / 2538 bucket lift cylinders...the stainless tubes #4
Doesn't have to be "Mahindra" cylinders. They don't make them anyway for the 2538. But you need ones with same size pins, and flow rate.
My control valve body went to junk, and I replaced it with a generic valve body, and works just fine.
Well since none seem to be available ... I capped and bypassed the front cylinder lines so I can still run and the tractor ....backhoe is still working.... Stump digging will keep me busy for bit! Thankfully it's not winter with SNOW!
Follow up...thanks for the replies and ideas...
what I got from a 'local component shop'... the bent and gouged condition of the tube.. ...repair was a futile road to go down.
   / 2538 bucket lift cylinders...the stainless tubes #7
You can buy new cylinders for not much more than seal kits from Mahindra. You might even find one with larger rods that won't bens so easily.
   / 2538 bucket lift cylinders...the stainless tubes #8
That's what I was trying to communicate. Use a different "brand" than Mahindra. Guess I didn't do a good enough job. I'm going to save the link myself, as at some point, I'll need to replace one, or more.
Thanx for the research.
duffer...'communication received and understood' ...I'm not fussy, looking at all brands
Follow up....machine shop located a pair.... I installed and am working again!
72in Dual Cylinder Grapple Skid Steer Attachment (A51691)
72in Dual Cylinder...
KENMORE ELITE REFRIGERATOR/FREEZER COMBO (A51248)
KENMORE ELITE...
2005 Ford E-350 Cargo Van (A51692)
2005 Ford E-350...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
UNUSED X-STAR PORTABLE 300 GAL FUEL TANK (A51247)
UNUSED X-STAR...
2013 WABASH DVCVHPC 53FT DRY VAN TRAILER (A53426)
2013 WABASH...
