Woods Brush Hog Gear Oil
   / Woods Brush Hog Gear Oil #1
Buckchaser
Member
Bradford PA
Massey F 1734
Can anyone let me know which gear oil is best for an older Woods Brush Hog and also for a rear tine King Kutter tiller ? Thanks for your help.
   / Woods Brush Hog Gear Oil #3
The manual for my 22 year old Woods BrushBull 60 calls for 80 or 90 wt, GL 4 or GL 5 gear oil in the gearbox.
   / Woods Brush Hog Gear Oil #5
OK. Thanks All. I have 80-90 wt. I will use that.
Should make sure it's also a GL4 or GL5. Those grades can handle higher pressures and resist shear better than lower grades.
   / Woods Brush Hog Gear Oil #6
   / Woods Brush Hog Gear Oil #8
I use "Corn Head" or grease 0 it is all that I use in all my gear boxes old or new. An since most gear boxes do not have a drain so you can change/flush the lubricant for the most part it is a fill and forget deal unless there is a major failure.
   / Woods Brush Hog Gear Oil #9
Don't know about no corn picker cotton heads but down here we use full synthetic 75-145. Comes in a new limp squeeze tube now. :rolleyes:
   / Woods Brush Hog Gear Oil #10
80-90 GL5 is what I use.
Ain’t never seen any cotton picker grease in a store around here but no one grows cotton around here either.
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
