Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #23,821
Those of you using tote cages for wood - so far I've cut a window in one side of mine, but I've left the top ring undisturbed. Has anyone had trouble with the cage spreading open because of the top ring being cut, or do they seem really solid still?
It's definitely a pain to reach deep into the tote with that top ring in the way but I was concerned about long-term stability.
I suppose if it was water in a soft bladder there'd be too much pressure pushing outwards, but the wood is almost entirely pushing downwards, with just a bit leaning on the sides so there's not a lot of stress on the cage?
   / Tractors and wood! Show your pics #23,822
Those of you using tote cages for wood - Has anyone had trouble with the cage spreading open because of the top ring being cut, or do they seem really solid still?
No problems here with the top band being cut. I can't imagine reaching logs out of the bottom of the tote with that top bar in the way! no thank you.
The only thing I will note, is that if you are stacking a FULL tote of wet wood atop another one that is cut out, yeah it can spread a bit. So far that hasn't meant I've had any problems stacking them - yet.
   / Tractors and wood! Show your pics #23,823
What do you think ? The fir stumps should not be as tough as the hardwood you did and the machine is totally manual but again no clue what that means having never run one. Thanks
How long ago were the trees cut? As you know, they are soft wood and will rot down fast. I took out an old maple stump which was on my mother's lawn. After getting a quote of $300 I realized that a bar and chain were cheaper, so dug down around it some, put an older chain on my 545 and started cutting. By the time I got the stump out the smoke was pouring off the chain and I got quite a workout, but managed to keep from burning up my bar. A new chain was around twenty bucks.
   / Tractors and wood! Show your pics #23,824
From what I can tell the stumps aren't to old - no signs of rot and solid, bark still sight, but discolored to grey. What you did with your saw was our initial thought also then as we waited for cooler weather I started wondering about a grinder. From what I learned above the saw them off flush method will probably be what we do. I have plenty of old saw chains. They have tiny teeth, some broke too, but still cut and are totally expendable.
gg
   / Tractors and wood! Show your pics #23,825
I do not stack my totes of wood. If I did I would want that top ring intact. No problems with cutting out the top ring and part of the side and my totes hold 1.4 face cords of wood with how I modify them. Cannot post a picture from this device but they are pictured in this thread in old posts.
   / Tractors and wood! Show your pics #23,826
I've stacked them without a problem in the short term. I have basically no flat land on my property, besides my driveway, so I can't store them doubled up. I would never leave the top uncut. That sounds horrible.
   / Tractors and wood! Show your pics #23,827
One word: "terrace". My wood processing area was also on a slope, but a rubble wall and an afternoon with the FEL now has me a nice flat terrace, where I do my processing and stacking. I did leave the area where my sheds are arranged a little sloped, so water runs off below them, I just stacked concrete block on the ground to create level piers under the sheds:
   / Tractors and wood! Show your pics #23,828
Heavy Duty Mr. Winterdeere! I'd be happy move into one of those !!!
The storage racks look to be maybe 7'(?) deep?
Do you stack with 3 rows of splits?
   / Tractors and wood! Show your pics #23,829
View attachment 940280 View attachment 940281
View attachment 940285 View attachment 940284
very nice design... I wish I would've seen this before I built mine, I would've done wider overhand but very nice.
   / Tractors and wood! Show your pics #23,830
My latest stoves operate best with 18" lengths, so I cut to 18" and stack two rows deep on the front side of the shed and another 2 rows deep on the back side, for four rows total depth. I did it this way so I can easily stack or retrieve wood from either side, without having to walk into a deep shed. I'm moving a lot of wood (up to 14 cords some years), so I want to make it as quick and efficient as possible. every step counts when you're repeating it thousands of times per year.
The base of each rack is 6' x 16' = 96 ft2, as our township requires a permit for anything over 100 ft2, and I wanted to stay just below that. There is a roughly 10" overhang on the roof, to keep the wood dry in raking wind, the roof is actually closer to 7' 9" ft. deep.
Having dry wood is priceless, when you're trying to actually heat with it, versus just ambiance fires. We have about 8100 sq.ft. here, and I'm heating about 7800 sq.ft. of that. Wood carries the majority of the load in something like 5800 sq.ft. of that space, with the balance covered by a mix of oil, electric, and propane.
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
Informational Lot - Financing (A56438)
Informational Lot...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
