How to make Railroad ties last longer?
   / How to make Railroad ties last longer?
I think I am going to bite the bullet and get a scoop of gravel to put against the ties. I have a material yard right next door to my property that lets me come in and grab a scoop at a time. (I know, what was I complaining about right?). I did a quick calc and it is about 20 cuft. Which is about 1 bucket full on my machine. I also have some left over road fabric that I can use to hold it up against the ties while I spread the dirt up against them. Kind of a no brainer, just an extra step I didn't want to do. But it is best if I do I reckon!
Well, its done!! It was not easy to hold 57 rock against the ties before I backfilled. Used geotex fabric stapled to the bottom then filled it and then pulled it to the top. Worked ok, and I ran out of stone. But whatever, its done!! I backfilled it with some nice dirt I got for free from a project down the road. It was LITERALLY the perfect amount. No pics because it was dark by the time I finished. I will snap one tomorrow. I have some questions about super dry fill, and rain and extra compaction but I think I am going to start another thread. Stay tuned for pics. Only afters because I am the worst at taking befores.🤦‍♂️
   / How to make Railroad ties last longer? #26
To make railroad ties last longer, consider applying a few effective strategies. First, placing a plastic barrier between the ties and the soil is a great idea; this helps prevent moisture from seeping into the wood, which can lead to rot. Additionally, applying a used oil treatment can provide some level of protection against moisture and pests, but be cautious as it may not be environmentally friendly.
Instead, consider using a wood preservative designed for outdoor use, which can enhance longevity without harmful effects. Lastly, ensure good drainage around the ties to minimize water accumulation, as excess moisture is a primary cause of decay. With these steps, you can help your railroad ties withstand the elements and last longer in your mom's backyard shed project.
Are you a real human?
I was wondering the same thing. Sound very AI generated huh? Their other post sounds the same. Very interesting if AI is going to start jumping into the mix.
   / How to make Railroad ties last longer? #28
If you are talking "real" RR ties - they should last forever with no added help. I have four - serving to hold up two gates. Installed in 1982 and still solid as a rock.
If you are talking about the crap sold at you local hardware store. Well - you are going to get exactly what you pay for.
   / How to make Railroad ties last longer? #29
Built a small porch with real creosote oozing 4 railroad tie posts.
For 30 years they looked fine and then moving a refrigerator the fount that termites had completely hollowed out the ties from the inside.
The outside 3/4 to 1.5” perfect but nothing inside except very upset termites…
   / How to make Railroad ties last longer? #30
In the heat of the summer - you can smell my RR ties from twenty feet away. Lucky - around these parts, no termites. We do have the occasional wood boring bee. Don't seem to like my cedar home or those "juicy" RR ties.
However - there must be a valid reason that prestressed concrete ties are now being used.
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
LOT: (2) Bucket Hand Pumps: (1) Gear Oil 1/2 Full, (1) Tranny Fluid 1/4 Full (A59076)
LOT: (2) Bucket...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
