Saw Mill engine--->Kohler 14 hp CH440
   / Saw Mill engine--->Kohler 14 hp CH440 #1
Gitche Gumee Kid
NW WI
IH 284
My dilemma.Do I need a new engine or can t be salvaged?
My rookie mistake --->Replaced a leaking gasket on carburetor ( engine worked fine before leak developed )
After reassembly , I could not turn engine over with recoil type starter. It acted seized or locked up.
I opened both oil level plugs and out poured mixture of engine oil and gasoline.
Advice needed . I'll call myself a knucklehead to save you the time.
GGK
   / Saw Mill engine--->Kohler 14 hp CH440 #2
The crankcase full of liquid is probably what kept the crank from turning. It should turn now. If not then something else happened like a part went into the engine through the intake. If it's free then it should be fine once you fix or replace the carb.
   / Saw Mill engine--->Kohler 14 hp CH440 #3
The issue is the float valve is not sealing allowing the carb to overflow and fill the engine cylinder and crankcase with gas. Will need to remove, clean and repair the carb.
   / Saw Mill engine--->Kohler 14 hp CH440 #4
this looks like a honda clone,, remove carb and basically clean the float needle seat with a q tip and carb cleaner also clean jets you tube Kohler ch ch 440 carb clean.. also change your oil.. good luck
   / Saw Mill engine--->Kohler 14 hp CH440 #5
Actually based on collaboration with Subaru.
   / Saw Mill engine--->Kohler 14 hp CH440 #6
Take the sparkplug out and spin it over to clear the gas and oil out.
   / Saw Mill engine--->Kohler 14 hp CH440 #7
If there is room on a fuel line, install a fuel shut off valve to keep this from happening again while off.
Year: 2017 Make: International Model: DuraStar 4300 Vehicle Type: Truck Mileage: 45,026 Plate: Body (A51692)
Year: 2017 Make...
GEHL RB1470 TOTAL DENSITY CONTROL HAY BALER (A51247)
GEHL RB1470 TOTAL...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
