DarkBlack
Elite Member
I’ve got a pair of those too. I call them them log tongs
That’s makes sense, that’s what I will call them now tooI’ve got a pair of those too. I call them them log tongs
If someone has a photo Id be interested in seeing. Thanks!Recall seeing somebody had rigged a mount with a hookup similar to the log tongs on the rear 3PH to allow skidding logs
I've done this, but it really doesn't work very well, unless you have a very smooth terrain and a very narrow range of log diameters close to ideal for a given tong size. More often than not, every damn log hops off the tongs six times on your way to your destination.Recall seeing somebody had rigged a mount with a hookup similar to the log tongs on the rear 3PH to allow skidding logs. Looked simple to drop over a log, lift and go.
If I recall, it was chained to the drawbar also, so the actual horizontal pull for the tow was anchored low, not from the top link.
That is impressive. Stacked too!The wood wall is nearing completion. 29 totes in the first row and 22 in the second for a total of 51 so far
