Heating 12 by 20 Insulated Shed
   / Heating 12 by 20 Insulated Shed #1
WVH1977
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck John Deere LX178
Hello all,
I built a 12 by 20 shed that is fully insluated. I have power to it (6 breakers, 2, 20 amps, 4, 15 amps). I am trying to decide on the easiest way to heat it this winter for around 4 hours a day when it is being used. Not looking to do a mini-split right now. Thinking about a kersosene heater.
What advice/opinions would you have on heating something like this?
Thanks
   / Heating 12 by 20 Insulated Shed #3
The propane option above would work well, or diesel powered heater such as one of these;
Route just the exhaust outside and enjoy.
I got one a couple of years ago to use in my SxS and it works great.
   / Heating 12 by 20 Insulated Shed #5
I would do a mini split. Summer is next. A year round conditioned space is a nice to must have.
   / Heating 12 by 20 Insulated Shed #6
I wouldn't use a kerosene heater unless it's ventilated area
I use to use a Kerosene heater. Then my small room started getting a slimy feel to everything. Plus, it STUNK. And the price for fuel was not even cost effective. I went with an electric spot heater. No stink, no mess.
You can mount it to the wall, or use it as a stand alone. I have it on the wall so it will not get bumped over.
   / Heating 12 by 20 Insulated Shed #7
Last time I bought kerosene, I thought it was expensive compared to other fuels.
   / Heating 12 by 20 Insulated Shed #8
You might try an oil radiator heater. They’re cheap and relatively safe. But you have to leave them on because they take awhile to heat. They will keep a warm room warm if left on, but they won’t warm up a cold room quickly. They are fairly economical to buy and operate.
   / Heating 12 by 20 Insulated Shed #9
This is what I use for my workroom area where I do my reloading and other odds/end jobs. I spend quite a lot of time in there in the winter. Turn it on when cold weather gets here and turn it off in the spring. Built in thermostat keeps it comfortable for working. Also have a small AC window unit for hiding out in hot weather.
   / Heating 12 by 20 Insulated Shed #10
I had one of the kerosene jet engine looking heaters and it worked OK, it requires a special thermostat and you can buy a liquid product that will eliminate the smell. I wouldn't recommend it but it worked OK.
They also have a propane jet engine looking heater my friend had one and it was pretty loud but did a good job.
You can also buy a 120VAC 11,000 BTU window AC unit with a reverse heat pump, I had another friend who had one in a detached shop about the same size shop as yours.
If I was going to buy something today I would buy the AC unit with the heat pump. It is quiet works pretty quick and is an all season unit. If WIFI you can remote start a short time before going to the shop.
   / Heating 12 by 20 Insulated Shed #11
I heat my 12x32' camp with one of these when I'm not there. It's plugged into a space heater thermostat which I set at 50 degrees to keep things from freezing.
   / Heating 12 by 20 Insulated Shed #12
My brother has one of those cheap diesel heaters to heat his greenhouse over the winter and it does a heck of a job and doesn't take all that much fuel... and that's in a greenhouse that's not insulated and single layer plastic on the roof and sides above 3' (plywood under that) and I think 10'x16'
   / Heating 12 by 20 Insulated Shed #13
From what I remember from youtube, seems like the key to those diesel heaters is clean fuel, clean fuel filters and maybe it was the spark ignitors?
   / Heating 12 by 20 Insulated Shed #14
If only four hours a day and not every day I would go with a couple of the oil filled electric radiator heaters. Cheap to buy and run. Leave one on low all the time to keep the room from freezing then turn both on high when you are gonna be there for a few hours.
RSKY
   / Heating 12 by 20 Insulated Shed #15
I have a fully insulated 12x24 hobby room that gets occasional use. I heat with the Vevor 8kw heater shown on pg 1. I burn red diesel. I tried mixing in used motor oil. Good in theory but ended up needing to replace the glow plug, so no more oil burning. I mounted the unit outside and simply ducted the heat into the room. I keep a battery in the room and the control. Works good but still can smell like a diesel burner. For cooling I got a small thru the wall AC unit. Seasonally I use one or the other but we are in a pretty mild winter climate
   / Heating 12 by 20 Insulated Shed #16
I’ve got a 24x32 shop I work out of daily..
The wife bought a kerosene heater for me last year.
I went broke buying the fuel.!!! I could get 20 hrs out of a tank.. I opted for a double burner propane heater instead..
If u put a small fan behind it, you can direct the heat any which way.. just my .02..
   / Heating 12 by 20 Insulated Shed #17
For such a small space, and you're only in there a few hours a day, I would use electric space heaters. Probably two of them at either end to get the temps where you want them, and then turn one of them off to maintain the temperature.
When you say fully insulated, what R Value are you at? How good is your wind barrier? Two biggest issues with insulating a building is keeping the wind out, and having a high enough R value in the ceiling.
Here in East Texas, R40 is now the minimum for an attic. I personally have R60, which is considered the highest you can go before you're wasting material without any more gain.
Wall R value isn't that big of a deal because wind is the bigger issue. Make sure your window and doors are sealed, and you have a good house wrap that is also sealed. R13 in the walls is usually plenty.
When my mom grew up in Northern Saskatchewan, they left a candle burning in the outhouse to keep it warm in winter. From what I'm told, it gets really cold up there, but they didn't have electricity, and a candle is all they had. If the building is insulated enough, it doesn't take much to warm it up.
   / Heating 12 by 20 Insulated Shed #18
@WVH1977 I'm not a fan of non-vented combustion heat in enclosed spaces, but that may just be me. There are the partially burned fuel residues, the carbon monoxide and dioxide, and all the water from burning the fuel.
I'd rather seal and insulate the space and then use something simple like oil filled heaters, electric space heaters, or a minisplit. With good insulation and the air leaks removed, it doesn't take a lot of heat or cooling.
All the best,
Peter
   / Heating 12 by 20 Insulated Shed #19
The diesel heaters mentioned have exhaust pipes to be routed outside, they function just like little furnaces.
I dont remember the Rvalues exactly but I used 6 inch insulation in the attic and floor and 4 inch in the walls. I want to say I used R40 in the attic. It was the pink panther stuff. lol I wrapped the floor and walls with Tvek and used that black tape around windows doors and floor where needed. Forgot what fabric on roof but it was wind/weather/water resistant.
Not a builder but tried to button everything up tightly.
2020 DRAGON ESP...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2000 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2000 Freightliner...
John Deere 644J Articulated Wheel Loader (A59228)
John Deere 644J...
CATERPILLAR 305CR EXCAVATOR (A60429)
CATERPILLAR 305CR...
