My case 580B has a reset button on the dash, can anyone tell me what it does?
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #1
somanytractors
atlanta, ga
several
I've attached a few pics.
I have no idea what this is for.
It just says push to reset, and it looks like a hose coming out of it and going under the hood.
I didn't trace it because even if I did find where it goes, I still wouldn't know what it does.
Any info would be greatly appreciated
Yellow Machine Fastener Rust
Yellow Rust
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #2
That's the air filter restriction indicator.
Once the air filter is clogged enough, it will trip that little indicator to warn you to clean or replace the air filter. It will show a ring on that clear section of it, probably red or yellow or similar. Once the air filter is either clean or replaced, you push to reset the indicator.
EDIT: As they say, a picture is worth a 1000 words. This should make more sense:
ptsg, Thanks soooo much. I would never have figured that out.
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #4
Reset the Flux capacitor?
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #6
Resets you back to 1980
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #7
It’s kind of like the undo button in software if you screw up.
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #8
Resets the garage wall to be complete instead of having that hole you just put in it by accident
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #9
Its a indicator from when your wife wants you to stop playing on the backhoe.
Just hit the reset button and she goes away.
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #11
The FilterMinder reset should be pushed occasionally to see if the FilterMinder is actually working as designed, and to see how fast the indicator closes in on "replace filter".
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #12
Uh oh... I probably shouldn't have done that..... Quick! Hit that undo button!
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
24in pin on excavator tooth bucket (A56438)
24in pin on...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
John Deere 25A Flail Mower Tractor Attachment (A59228)
John Deere 25A...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
