Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,691
I've seen videos where screws are used to split a log, starting not at the end but somewhere in the middle. Like, split first, then chainsaw it to lengths.
Usually seen on skid steers, with hydro motor on SSQA attachment.
   / Tractors and wood! Show your pics #24,692
Splitter cycle time is important but it is only part of the whole cycle of getting the block onto the beam and the split piece dealt with. No matter what a single person operation will be fairly slow. To me the key is to minimize your foot movement. I like several methods. Block up the logs on my trailer and throw the splits into the wood shed.
Or block up tree length logs into a pile. And roughly stack the splits to air dry.
You will want an ample table on your splitter. I also use the bucket if I have a large half I split and want to get it out of the way while I work on the first half.
gg
   / Tractors and wood! Show your pics #24,693
My dad on his custom made splitter has a hydraulic wings on the opposite side of the controls that you can stack wood on so you don't have to go back and forth every logs
I Also really like the moving wedge two way splitter, that compensate for slower cycle time.
   / Tractors and wood! Show your pics #24,694
My dad on his custom made splitter has a hydraulic wings on the side opposite side that you can stack wood on so you don't have to go back and forth every logs
I Also really like the moving wedge two way splitter that compensate for slower cycle.
Nice setup. I have my father's old basic splitter. He had welded 2 pieces of angle iron together to set behind the ram, stopping it with enough space for a 16 inch stick of wood. Unfortunately it's been lost over the course of time and I haven't had a chance to build another.
   / Tractors and wood! Show your pics #24,695
That's a good idea - But just a warning, it didn't work out well on my Huskee splitter when I did that to stop at 18". On the return stroke it tore the bolt holes right out of the wedge. I didn't realize that the ram to wedge connection was designed to be push only where the ram end was in contact with the wedge. The bolt was there to hold the ram and can't withstand much force. You can see where I had to repair the bolt holes.
gg
   / Tractors and wood! Show your pics #24,696
I've seen the cylinder rod end fail, more often than the wedge cheeks. You'll see this most often on splitters that have been "short-stroked" with collars on the rod, if the detent pressure on the auto return isn't backed way off.
   / Tractors and wood! Show your pics #24,697
Not true at all. The only accurate way is to count the rings. There are a lot of factors involved in how fast a tree grows. Species certainly is one, but site, available water, completion from other trees are even more important. You can have two trees of the same species and age side by side; but if one of them gets adequate sunshine and the other is in the shade of another tree there can be a tremendous difference in height and diameter.
Come to think of it there is an exception to every rule. If your grandfather planted the tree on his 21st birthday...
In northern Wi in the 90s I would camp at secluded lakes, some of which had been former ccc camps. All of the trees were regrowth of cutover areas from the 30s, making them all 50yrs old or so. I would go around, cut down a few dead ones and put together a star fire (log lengths that all meet at one end). No other cutting, just keep shoving the logs toward the center. Thing was these dead ones were 3-4" dia, could never get above the canopy, but were all also the same 50yr old age.
Also here at home, some of the 175yr oaks, the first 120yrs they might only be 10" dia, then the canopy breaks, and they shoot up to 36" dia.
   / Tractors and wood! Show your pics #24,698
Because our area was nearly clear-cut in the 1700's, and various areas wooded today vary from the rare old-growth up to forests as young as 60 years, we get to see the effects of growing under all sorts of conditions. Trees that grow under a canopy will usually rocket straight up, I've seen young black walnut trees 100 feet tall and only 8" in diameter, reaching for the sunlight they need. Meanwhile, the same species grown in a front yard or field will branch out and become quote old and stout, before ever reaching such heights.
   / Tractors and wood! Show your pics #24,699
I was lucky the cheeks ripped. The detent on my valve had no adjustment but was spec'ed at 500 psi. So 6000 lbs with the 4" cylinder. Some back yard engineering ......If the shear of mild steel is 40,000 lb/sq-in then 3/16" should hold. Each side was 3/16 so I had double ???? The dangers of backyard engineering :confused:
gg
   / Tractors and wood! Show your pics #24,700
I spent most of my life with loggers.
As with any profession, stories abound.
I totally disagree with your vehemence against this not holding any veracity whatsoever. I’ve seen it work at times and be totally incorrect with other times such as the tree Winter described.
It’s a generality that may be true at times and untrue on others give or take a few rings.
Ages of trees really didn’t hold a lot of interest to loggers and may have been brought up for the sake of curiosity. Nonetheless, as with most things in logging, inventing the fastest way to do stuff was the norm.
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
John Deere skidsteer (A55788)
John Deere...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A55745)
2017 DRAGON 150...
2020 VOLVO L70H WHEEL LOADER (A52706)
2020 VOLVO L70H...
