How thick are hollow core doors?
   / How thick are hollow core doors? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
We are doing some remodeling and had new flooring installed. They just put new underlayment down and the new plank flooring. We have a set of bi fold door that are now to tall. They have spring loaded pegs and rollers on the top that are compressed all the way. I want to cut some off the bottom and then reinstall the peg on the bottom that is the pivot. I need to cut off a little more than a 1/4 inch from the bottom. Will that expose the hollow part of the door?
   / How thick are hollow core doors? #2
You should be ok cutting 1/4” off. Generally the cheapie bifold doors have 1-1/2” top and bottom stiles. You could confirm by pulling out the spring loaded pegs and checking the depth of the hole with a piece of wire with a short 90 bend at the end.
   / How thick are hollow core doors? #5
I've had to cut several where that left no filler at the bottom and I simply glued in a new piece. Left a clamp on overnight.
Done the same thing. Works good
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
