nickel plate
Primary use will be from my Ford F-250 diesel to my attached flatbed trailer winch for on and off loading a 2000LB 1957 MGA roadster. I don't want copper clad aluminum.
not for a winch, the boost only lasts between 3 and 5 seconds.Would not this fit the bill? NOCO 4250A 12V Jump Starter
Don't know about cheaper but convenient and portable.
Definitely CCA at that price. Fine for occasional-use jumping, but CCA is basically just fine aluminum wire and shouldn't be flexed too often...Don't remember the brand, but I got some 1 ga jumper cables, 25 or maybe 30', from Amazon for about $50.
In my case to connect the trailer's Group 31 to the 3500's battery for long and/or heavy pulls with an 8K winch.
For a little MGA, and especially if it isn't a deckover trailer, you shouldn't need much winch power.
Even if it is, they should work for my application.Definitely CCA at that price. Fine for occasional-use jumping, but CCA is basically just fine aluminum wire and shouldn't be flexed too often...
