That BX1500 followed me home - 1500, 00, 30 age issues
   / That BX1500 followed me home - 1500, 00, 30 age issues #1
tshep
Gold Member
Richmond, VA
BX23 MLB
The dash, well, sucks.
Left side icons and colors under lamps have all cooked off, and the sticky tape seems to have darkened and lightened areas - in tape outline. (Even HST and it's peers cooked off.)
So, are we spending the 3 bills for new silver paint to cook off anyway, or DIYing a solution?
The 1500 also has, not a gauge, but a lamp for Low Fuel - a $6 round sticker over the gauge sized lamp.
Anyone changed one - I do not have the old to look at - seems like it would only stick to the perimeter?
Is it self shielding, no sticky elsewhere?
And I am an impatient mechanic. I seem to bloom mild steel pins - so many here and BX23/RCK - getting rusty round bar out of supporting stuff. Today it was the (non-split like the BX23) bar that mounts the rear lift arms and chains, only way to get that weight/length off. How does one remove rusted/aged pins without blooming from hammer?
THX!
   / That BX1500 followed me home - 1500, 00, 30 age issues #2
THX!
Red heat "shrinks rust".
It's a chemical conversion that only heat does. DON'T hit on the part while it's red hot! It's soft then.
Well, I am not replacing the dash panel.
This one (and as others write) curves way in to the driver in the middle. (I read new ones do too.)
I decided I would NOT attempt to recreate that dash: 2 holes and a square punch, a curve around the wheel out that would all have to be perfect to look right.
So....
I'm gonna' get a small piece of turned aluminum and make a much smaller piece to just cover the 5 lamp and 3 unused lamp spaces and mount 5 lamp bezels to replicate the colors. Only the parallel lines top, bottom, and bezels centers would have to be perfect.
Pics on completion!
   / That BX1500 followed me home - 1500, 00, 30 age issues #4
The dealership I work at part time has literally a row of old Kubota B series tractors in various states of decomposing.
He must have 30 or so. All run hard and put away wet, Must all be trade in's I suspect. Cute but basically worthless units.
   / That BX1500 followed me home - 1500, 00, 30 age issues #5
I just checked the serial number on my B7200.
Looks like a 1984 build date... (according to Tractor Data)
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
(2) 275 Gallon of Resinator Clean/Dust Down (A51573)
(2) 275 Gallon of...
New Wolverine Hydraulic Shift Pallet Forks (A51573)
New Wolverine...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
