Ed's 77 Terex 72-41 Wheel Loader
/ Ed's 77 Terex 72-41 Wheel Loader
We’ve spent some time up there, but haven’t ran the loader a whole lot. It developed a bad leak on one of the lift cylinders, I’m letting it sit now.
Here’s what Terex says to do about it.
I cut a log to hold the arms up, and plan to have the bucket off like in the image. My son is repairing the tripod, I plan to assemble it around the log when vertical, to hold the log up.
I also improved the spot I work on the loader, it’s actually level now, and wider.
I ordered parts to block off the cylinder and lines while I work on it, it’s a different type than the other cylinders on the machine.
The area also had an evacuation order for almost two weeks, due to the Basin fire. It got within 6-7 miles.
/ Ed's 77 Terex 72-41 Wheel Loader #625
Looks like quite a bit of work, rebuilt a cylinder then it looks like a new starter on an adapter plate.
/ Ed's 77 Terex 72-41 Wheel Loader #627
My last "HD" gear reduction starter came on an adapter plate, I ended up having to re-clock the starter on the adapter plate.
Got the original starter rebuilt, it spins noticeably faster. I don’t hear cranking, it’s just running all of a sudden. I’m hoping this’ll help with cold starts.
/ Ed's 77 Terex 72-41 Wheel Loader #630
I admire your determination Ed!
Hanging in with this long project is something to be proud of and now you're seeing the rewards. 👍
I’ve been raking the forest. Seems to me that someone advised us to do that, so I’m getting it done. This isn’t a wide brush rake like they put on dozers, but it’s working.
The forks got stuck in the end of the log, and wouldn’t let go. I thought the forks were under the log, I lifted it to get the choker cable around.
I had to cut some off, too heavy, plus a lot of ground resistance.
Digging out a stump. I think it’s ready to pull out now, it still wouldn’t budge after digging only two sides. It moves now.
Unexpected bonus, this stump is fat wood.
/ Ed's 77 Terex 72-41 Wheel Loader #635
Boy that engine sounds nice! :)
I haven’t had to run coolant from another vehicle through to warm the engine before it’d start, since getting the starter rebuilt. Seems it was just cranking too slow.
2012 FORD F-150 XL EXTENDED CAB TRUCK (A60430)
2012 FORD F-150 XL...
GREENHECK AIR DUCT FAN (A60432)
GREENHECK AIR DUCT...
17102 (A56859)
17102 (A56859)
7071CFL (A59228)
7071CFL (A59228)
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
