4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,576
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
air ride, power steering, ABS, automatic, A/C
How else would a driver be able to hang their foot out the window at 65? Hard to wear flip-flops and use that 3rd pedal.
Have you ever tried to jack up a trailer that’s 6” under the hitch? Aside from the obvious better ride quality an air ride truck makes hooking up much easier. An air ride truck requires less maintenance than springs. It’s hard enough get a big truck in a small yard with power steering. Power steering is basically a necessity. ABS is required by the government regardless of how well it does it doesn’t work. Nobody is making you use the ac but most drivers would quite and work for a different company that has ac. The automatic transmission is again less maintenance. If you’re stuck in hard mode for no apparent reason why don’t you just use a wagon?
