2023 L3560, 100 hours, suddenly rapping and hissing noise from engine
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #1
JerkyChew
shopping
So I fired up my tractor today, it's the L3560 with the cab. As I was driving I thought I heard a rapping noise coming from the engine. I opened the cab door and realized that in addition to the rapping there was a crazy hissing noise coming from the engine as well. I shut it off and popped the hood. I didn't see anything out of the ordinary so I fired it up again - Same problem, so I shut it off again in case there's a hydraulic leak or something. It has been sitting in my yard unused for about 2 weeks, but otherwise nothing out of the ordinary has happened to it, and it worked fine the last time I used it. The tractor was just serviced by the dealer at 80 hours and I have the extended warranty so I'll be calling them tomorrow, I just was curious if anybody had any immediate ideas. I know a bit about gas engines but not much about diesels so I have no clue what else to check, if anything.
I took a quick video of the noise. It's a little tough to hear the hissing, at least to my ears. YouTube made it a short for some reason:
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #2
Sure sounds like exhaust, rather than a mechanical noise to me.
Hopefully it will get straightened out with the dealer quickly.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #3
I can’t tell from the video, but an exhaust manifold leak would be my guess based on 8 seconds of video
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #4
I can't tell in video, but is it just doing a regen? I know my diesel trucks have a distinct and hissing sound when they regen.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #5
That's an interesting thought, but my L4060 doesn't sound like that during a Regen. Could still be related to the dpf though.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #6
OK, was just a thought because even my Cat wheel loader at work makes a loud hissing while it's doing a regen if you let it drop to an idle.
I wasn't sure if the small Kubota's changed sound also?
Thanks for all the ideas - I forgot to mention that oil appears to be dripping out of the exhaust as well. I'd video it but I don't want to start the thing and risk damaging it further. I've reached out to my dealer and am waiting to hear back. A loose manifold would be great, just because in theory it's not a sign of a larger engine issue. I don't think it's doing a regen because I didn't notice any lights or statuses on the dash, and I just did a regen not even five engine hours ago.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #8
Have you done the basics first? Check all the fluid levels? Oil, coolant, etc. Check the air filter? Pull it out and inspect.
So I found the issue - Turns out some critters had made a nest in my exhaust. I was on the phone with my local service department who had me fire up the engine again to confirm it wasn't a loose air filter cover or something, and I realized that the sound was totally coming from the exhaust. I stuck a pokey thing in the pipe and pulled out some hay, so I cranked the tractor RPMs up and it blew the nest across the yard! It's all good now, and I guess there's a first time for everything! Thanks for the help all.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #10
Glad you found it before it burnt to the axles!
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
40ft High Cube Shipping Container (A54865)
40ft High Cube...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
