John Deere 30 inch mechanical tiller disassembly problem
   / John Deere 30 inch mechanical tiller disassembly problem
The locking collar and the inner race of the bearing are still there as you suspect. A cutting torch will take those both off easily, but if you don't have one, a propane, preferably a MAP gas torch can be used to heat both pieces to a orange, red color, then cooled to loosen them up to beat off with a hammer.
Sand the shaft to remove burrs. A socket or pipe of the diameter of the inside race is proper to tap the new bearings on to the shaft. Yes, replace both bearings. There appears to by a snap ring or something beyond the bearing race. The book doesn't show anything AND it doesn't show a seal. There should be a seal in the case to keep the grease in and dirt out. I don't see one, so the tolerance between the shaft and housing should be very close and no wear at this point.
The "dust" in the chaincase is not a good thing and indicates that the grease leaked out. At this point, clean the case, chain and sprockets thoroughly then use corn head grease, such as Tractor Supply Super S #00 Cotton Picker Spindle Grease
I opted to use a dremel cutting wheel and chisel to get the locking collar off. Once that was removed I found that the inner race moved freely around but would not move freely off the sprocket shaft. Looking at the shaft closer I wonder if it is just a light rust coating that is stopping it? Can I use naval jelly on that shaft or will that cause a problem with the steel on the shaft one day? Also there was an interesting "ridge" visible along the shaft when I removed the collar. I wonder if that was made into the shaft or if the setscrew of the collar shifting on it would have caused that ridge? It looks really too uniform for that to be the case. What can I use to smooth out the shaft evenly? You suggested sandpaper but I don't I want it smooth when finished or will that not matter? I may cut the "good" bearing off of the other side but I might try a bearing puller first--looks like I can pick one up for under $50. As for a seal--the chain and inside case will be repacked with grease AND a sealant used on the edge of the case when I close it back up. I would think that grease will enter between the spindle shaft and bearing but that looks to be by design. Since there is a dirt cap (item #6 on the drawing) I suppose that unless the dirt cap gets compromised--which is what happened to me (it rusted at one corner and allowed dirt and moisture in) it will work. Thank-you for your suggestions. This sort of thing is not what I am in any way familiar with. Electronics troubleshooting and repair was my life until I retired in 2021.
   / John Deere 30 inch mechanical tiller disassembly problem #12
Rough spots are what is stopping it and sanding the shaft would be fine. Smoothing it out is what you want. Any kind of lubricant would help in assembly and would not hurt anything longrun.
I didn't see the dirtcap. The tolerance between the inside of that and the ridge/ring that the bearing slides against should be very close.
   / John Deere 30 inch mechanical tiller disassembly problem #13
Also when you tighten up the collars on the bearings during reassembly, they need to be tightened up in the opposite direction of shaft rotation. Otherwise they may loosen up over time and cause a worn area on the shaft.
So would naval jelly be helpful or harmful before sanding? Would it be better to just sand it?
   / John Deere 30 inch mechanical tiller disassembly problem #15
I always sand the rust and foreign material off of shafts before reassembling. Usually I sand as much of the shaft as I can before taking the bearing off as it makes it easier to slide the bearing off.
Ordinary sandpaper works ok but I buy emery cloth. Just tear a strip off as long as you want and wrap it around the shaft and polish to your hearts content. 100-200 grit works quite fine though a finer grit works ok too.
I have no experience with naval jelly but if it works I don't see the harm in it.
   / John Deere 30 inch mechanical tiller disassembly problem #16
Navel jelly, petroleum jelly? Would be fine.
Or, use the grease you are going to use in the gearcase
Any ideas for sanding the inside of the tiller shaft that got "ridged" from whatever burr was on the sprocket rod? I need to sand as far as about 4 or 5 inches into the metal tube. I'm looking at a sanding drum from Amazon--4 1/2 inches x 1". Not sure if it will work but it will only cost me about $25 to find out.
I decided against using any naval jelly. I remember using it on metal furniture before painting and the metal acts sort of strangely afterwards--almost like it tends to rust even more. Phosphoric acid. I'm just sanding.
   / John Deere 30 inch mechanical tiller disassembly problem #19
Do you have a die grinder? If not get one for the job. They can be either electric or air with air being cheaper as long as you have enough of a compressor to run one. An electric drill might work but it's quite slow compared to a die grinder.
I use a 1/4" rod and cut a slot in the one end long enough to slide the emery cloth into. Slide the emery in at about the half way point of the strip and wrap it around the rod several times. As the strip gets worn you can tear about an inch off so that new emery gets in on the action. This setup will polish the inside quite nicely.
Another tip is that there are different qualities of bearings. Better ones last longer. Your bearing supplier should be able to help out with that. Also if you don't want as much rust the next time around purchase some sort of "never seize" and coat everything you have sanded with it during reassembly. It's messy to use but makes redoing something later much easier.
   / John Deere 30 inch mechanical tiller disassembly problem #20
Naval jelly - phosphoric acid - leaves a thin layer of iron phosphate that'll actually protect the metal, and phosphoric acid is relatively weak and takes a long time to affect clean steel - but it really goes after rust. To be safe, rinse a part you've used naval jelly on well, and then rinse with some baking soda solution to make sure you've neutralized any remaining acid, and rinse one more time with clean water.
I don't want to talk about navel jelly though
2013 John Deere 824K Wheel Loader (A55302)
2013 John Deere...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55302)
Adams Load Out...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
10 Snow Plow W/ Bracket (A47477)
10 Snow Plow W/...
Sunflower Windmill (A53316)
Sunflower Windmill...
2003 Ford Ranger (A53314)
2003 Ford Ranger...
