Montana 3040 electric wiring for fuel shutoff solenoid
   / Montana 3040 electric wiring for fuel shutoff solenoid #1
concrete guy
Mathews, VA
montana 3040
Hello tractor guys, any buddy have a ny electric wiring diagram for the shutoff solenoid, I don't know if is a relay before the solenoid, I sill appreciate thanks in advance
   / Montana 3040 electric wiring for fuel shutoff solenoid #2
Did you ever get an answer to this question? I have a diagram.. I think will work for you. Its for a 3040 and 3840... Im using it for my 3440 but its not complete for me for what I need.
   / Montana 3040 electric wiring for fuel shutoff solenoid #3
Assistir, If you are still active... I would love to check out your 3840 wiring diagram. I purchased the PDF manual (download) for the tractor, but it doesn't contain the electrical schematic. My tractor is doing something similar to the Concrete guys. If I am running multiple electric components - such as the PTO solenoid and turn on the lights, it kills the engine. Or headlights, then hit the brakes (switch), it will kill over. I checked the grounds and connections that I could see. It is charging to 14+ Volts at idle. Even had a meter on it when I ran pto then headlights then hit the brakes. Voltage only dropped like .5 Volt. I am sure it's a worn out circuit breaker or a bad solenoid. Thanks for your help
   / Montana 3040 electric wiring for fuel shutoff solenoid #4
from the 3040 - 3840 service manual.
Gary
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
Hyster H225E Forklift (A47477)
Hyster H225E...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2016 John Deere 755K Crawler Loader (A47477)
2016 John Deere...
