Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve
   / Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve #1
Lykins Farm
Member
Shelbyville, KY
1995 New Holland 5610S
I have a Ford 5610S. Just changed the five O-rings under the unload valve on top of the Hydraulic Lift Cover. Very easy and simple job. However, when I got things back together and tightened down, there is a squealing sound coming from the rear 3-point hydraulic when lifting. I think there is more than likely air in the system, but I have no idea where to start on bleeding the air out of that is the issue.
It did not make this squealing sound prior to replacing the O-rings under the unload valve. I tried to attach video but it won't allow me. If you want to hear it, message me your email and I'll forward it
   / Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve #3
Video asking for permission. I checked viewer, but nothing happens
I gave permission to a Ted Johnson. If that wasn't you, can you request permission and I can go to email and give the okay. Not sure why it is asking permission.
   / Ford 5610s 3-point Hydraulic Squealing after replacing o-rings under unload valve #6
Is the sound coming from the unload valve?
1000011568.mp4
This video should work guys. Sorry I am not good with uploading videos.
STRICKLAND 24" EXCAVATOR BUCKET (A54756)
STRICKLAND 24"...
2001 DODGE RAM 1500 LARAMIE SLT TRUCK (A54756)
2001 DODGE RAM...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
Portable Restroom (A54865)
Portable Restroom...
