PVC Pipe on cutting edge of snow blade
   / PVC Pipe on cutting edge of snow blade
If you just turn the blade around backwards, it will work fine and you won’t have to mess with contraptions.
You're going to have to explain how that trick works.....
   / PVC Pipe on cutting edge of snow blade #23
He was probably thinking about a rear blade on a tractor. Most of those will pivot and can be spun around backwards.
Yeah well, that reversing the blade doesn't work well with heavy wet snow. Tried it a few times, snow doesn't like to slide across the back of the blade as well as it does the front.
   / PVC Pipe on cutting edge of snow blade #24
Because you use it in reverse and it acts like the front blade on a truck
My betting money is on you
   / PVC Pipe on cutting edge of snow blade #27
It actually does if you get the top link angle and blade angle set right it will roll even wet snow.
Kubota L3130 (A53317)
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2015 Ford F550 (A55973)
2015 Ford F550...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
2015 Audi A4 Sedan (A56859)
2015 Audi A4 Sedan...
3ft Metal 5-Point Star (A55853)
3ft Metal 5-Point...
