Does anyone own one of the modern cast iron or carbon steel frying pans?
   / Does anyone own one of the modern cast iron or carbon steel frying pans?
I let my dog lick it out and then scrub it down with soap. I know a lot of people think otherwise but I’ve had zero issues scrubbing cast iron with soap.
I get the dog thing :) but wash it real good in hot water with soap and be careful. You never know where those lips have been.
We are using cast iron for most of our frying now. We have my Mom’s 10” cast iron, a couple of smaller ones (6” and 8”) from great uncle Johnny and a newer light weight 12”. To clean them, just heat them up for a good minute and boil a cup of water in the microwave. Splash the hot water into the pan and the gunk just boils off. A quick scrub with a plastic scrub brush and rinse with the rest of the water. Re-oil with grape seed oil to maintain the surface.
Does anyone use canola oil? That was my plan because we already have it and I read to use it for initial seasoning.
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #13
I have always used flaxseed oil. But canoa should work fine.
The problem with lodge is they have a texture to them. IMHO that is what causes them to stick initially. THe older/better cast iron pans have a smooth surface either from use or an extra step at the factory. I have taken the grinder/sander to a couple of Lodges and it helps considerably. I live close to the Lodge factory and they have a store that sells seconds.
We have a new fancy induction stove so we are trying to get away from the HEAVY cast iron pots. Already broke the top once, DO NOT want to do that again. Thinking either carbon steel or a decent stainless tri-ply.
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #14
I used to use soap and water, re-season, but never got the finish I wanted. Then I discovered cleaning with a little oil and a couple tablespoons of salt. After a few weeks of cooking and cleaning that way, I now have a smooth, very non stick surface. It is super smooth and shiny. I use whatever oil. If I ever get real hard crusties, instead of a paper towel, I'll use foil/oil/salt combo. Hasn't touch water in quite some time.
One of the positive features of the thick, heavy cast iron pans is the ability to maintain temps much better than any type thinner material.
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #15
I've heard that old cast iron is better than new. The thought is that the casting method, metals used and finish were better. It's easy to find contradictory views however.
We have a couple we use frequently. If it's too crusty and stuck with whatever, I use a chainmail scrubber, maybe a little detergent, heat it dry and add a thin coat of oil - right now I'm using Avocado oil that the wife buys in a spray can.
We have a HexClad sauce pan the wife bought as a test. It doesn't live up to all the hype, but in all fairness it is holding up to the abuse my sons put it through, and it cleans up to a near new condition.
Since we're moving soon, the wife has decided to leave all the old cookware with our sons, and has purchased a full set of "Made In" cookware - that's the actual brand name. Haven't used it yet, but it's damned expensive so I hope it's worth it.
I'm not fussy, the only ones I don't cook with are aluminum or Teflon coated. My personal preferences are cast iron or stainless steel.
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #16
Yeah mine has a rougher finish than I would think is ideal. Maybe I will do what you did and sand/polish it to a super-smooth finish.
I use canola oil mostly.
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #17
I have a little stainless chain mail scrubber thing for cleaning any tough burnt on stuff from my cast iron pans
I think if I ever buy another Lodge pan, I'll try sanding it first to get a smoother surface.
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #18
Yeah, look it up, it's a thing. Many Youtube videos about it. I have seen videos where they literally polish the surface. Supposedly that is not good because it doesn't leave anything for the seasoning to "grab" onto. But a flap wheel and orbital sander up to 220 grit with a really nice seasoning and you are golden.
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #19
Hot water and a stainless brush for cleaning. Use olive oil when I cook. Over the years, it's gotten shiny and smoother!
   / Does anyone own one of the modern cast iron or carbon steel frying pans? #20
My wife seldom "cleans" the cast iron pans other than a wiping with a paper towel. That way the seasoning stays intact like it should. We have probably half a dozen different cast iron pans that we use on an induction cooktop or outside on the gas burner if I fry some chicken.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2014 DORSEY EXPANDABLE FLATBED (A59575)
2014 DORSEY...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
