OP
wxtrendsguy
Member
Update...battery was fine, gounding cable was barely loose and connectors had some rust and corrosion. Cleaned them all up and reassembled and good to go!
Thanks for the update. It seems like most bad battery problems are actually bad connection problems, usually the ground cable. When you suspect a suddenly bad battery you should always check connections.Update...battery was fine, gounding cable was barely loose and connectors had some rust and corrosion. Cleaned them all up and reassembled and good to go!
My Kioti recently did the same thing. After ruling out the battery by swapping to a known good battery I checked the fuse in the starting circuit and the starter relay. Both were good. I ohmed out the wiring and had a bad positive battery cable. The wire had corrosion inside the post clamp.2014 DK45 cab tractor. Used it on Sunday with no issues. Tried to start it Monday, turned key to heat plugs and indicator came on then when ready turned to on and "click" everything is dead and only the oil indicator light is barely on. Probably been 4 years since last battery replacement. Tried to jump start it from truck and no luck, put a trickle charger on it all night and again lights on dash lit up but turned key and dead.
If battery what size and cranking amps am I looking for. The owners manual is somewhere in a building but I cannot find it if my life depended on it...lol
Sounds like it was a victum of leakage either into the tractor or self discharge. Either way a charger and even a jump won't always bring it back.2014 DK45 cab tractor. Used it on Sunday with no issues. Tried to start it Monday, turned key to heat plugs and indicator came on then when ready turned to on and "click" everything is dead and only the oil indicator light is barely on. Probably been 4 years since last battery replacement. Tried to jump start it from truck and no luck, put a trickle charger on it all night and again lights on dash lit up but turned key and dead.
