Contemplating an electric go-kart as a small yard cart puller
   / Contemplating an electric go-kart as a small yard cart puller
Anyone have experience with an electric JD Gator?
Not sure if it's 4x2 or 4x4 yet; how well would a 4x2 do relatively unloaded on a rocky bumpy not-flat road (not quite a jeep trail but close lol)?
Gators seem a bit wide for our purpose but I love the power dump box for the wife + the electric drive for lots of very short trips.
   / Contemplating an electric go-kart as a small yard cart puller #12
There has to be something like this near you.
I'd never heard of a "steep hill chip" before, but I guess it's a thing. Would need more off-roadier tires.
Point is... gonna be WAY cheaper than anything that has a JD decal on it.
   / Contemplating an electric go-kart as a small yard cart puller #13
How about something like this:
I like this ali version
the "road" to the upper garden isn't a nice one and isn't likely to get better because of the buried boulders; these things as I mentioned in a previous post above would likely fall over due to high CoG versus narrow track. Also, very small bed so it would still have to tow a trailer for bulk weeding/pruning, and it would be pretty tough to pull a trailer with it while you're walking behind it.
   / Contemplating an electric go-kart as a small yard cart puller #15
We have an electric SxS Polaris Ranger for around the property duties, and occasional short drive on local roads.
I just can't emphasize enough that for the short and frequent stop/start use it gets, the electric drivetrain is far superior to an ICE drivetrain. If you have longer distances to drive, or cannot charge it as needed, that is a different matter. Plus, plugging it in is so easy, it almost never runs out of battery on our use.
I did have to replace the batteries once (ouch!), possibly earlier than would have been needed otherwise due to dealer neglect of keeping them charged. I spent a little more money to replace the lead acid batteries with lithium, so should not have to replace batteries for a long time. Also don't have to water them, flush the battery tray to prevent rot and corrosion. Not to mention that draining them most or all the way does not permanently wound them as would be the case with lead acid. And the EV is 500 pounds lighter than with the original lead acid batteries.
   / Contemplating an electric go-kart as a small yard cart puller #16
Maybe a gutted Suzuki Samurai? The gator sounds like a plan.
We use both an electric Golf cart, an old Cushman gas cart, also put a hitch on the JD X 500 with diff lock but none are 4x4 and no steep hills to traverse.
   / Contemplating an electric go-kart as a small yard cart puller #17
I used an old Cushman factory three wheel buggy until the batteries needed replacing. I loved it for electric fence moving as I did not have to get off to do most of the work. It was useless in mud but fine on hard ground.
   / Contemplating an electric go-kart as a small yard cart puller #18
Here is my unconventional thoughts on this. First, I have a little go-cart that I bought to let my friends kids ride when they are over at the property. I found it to be GREAT for riding around and picking up rocks and stick as I can sit and drive it around and just reach over and pick up things off the ground without having to even get out of the seat. I put a container in the passenger seat to put the items in.
With that said, it is difficult to get in and out of for people who are of a certain age. You know, us guys that obsess about what size fruit our prostate is! 8>) So it really wouldn't be great to have to get in and out of it more than once.
Have you looked at a used quad ATV in your area? Normally they are pretty affordable (not electric), but you can find them for less than 2 grand almost all the time.
But, I think most people overlook a great option. If you property will allow it, what about just getting a beater car? Even better if you can find a wagon. Something like a Subaru or something with all wheel drive. A/C Heat, radio, comfort, and getting in an out of it is a breeze. Plus, if you want to insure and register it, you have an extra car and you can use it to pick up dirty loads. Just another idea.
Yes, I think the UTVs are WAY overpriced for what they are. Golf carts are a great answer, but battery replacement is very expensive.
   / Contemplating an electric go-kart as a small yard cart puller #19
Get a used golf cart and put good tires on it.
Batteries are expensive but what isn’t?.
I put batteries in 3 years ago and still going good although I need to check the water in them.
   / Contemplating an electric go-kart as a small yard cart puller #20
I agree with the golf cart camp here. We had an EzGo that had a utility bed on it, and it was great for around the property. The guy before me had put a lift on it and some meatier tires. Gave it to my father when we got a SxS, and he takes it all over for trimming hedgerows. It was a gas model, but they are meant to stop and start all the time so it's really not an issue.
Your wife can use the bed that's on it, and if you had a need to use the two behind cart you could always still fire up your existing mower.
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2017 Ford F-250 (A55973)
2017 Ford F-250...
light tower (A56857)
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
