r8f1k
Gold Member
- Joined
- Jul 21, 2018
- Messages
- 303
- Tractor
- Farmall 100, Allis Chalmers D14, International Super MTA, IH 560, Mahindra 4510, Gehl 4500, Clark CY45, JD 800, JD 60
Ok, so I have minimal hydraulic experience, just enough to get myself in trouble and I know this is not a tractor issue. I have been restoring a 1910 hydraulic cider press built by the American Hydraulic Company. My 15 acre orchard is starting to provide me with the level of apples I would want to begin to make cider this year. I had the cylinder professionally rebuilt last year. I am finally getting the whole system together. I have a Vickers V10 hydraulic pump, nothing special, but works fine. I can get the cylinder to travel up, but I cannot get it to come down with the 4 way 3 position spool valve I had laying around for an old log splitter. I capped off the top work port and I am using the bottom one to get pressure. If I lift the handle up to try get fluid to come back to the tank, nothing happens. There is a HUGE piece of forged steel that makes up the bottom of the press (approx 250 lbs) and an additional 75 lbs of maple that both sit on top of the cylinder which, I think, should push the cylinder back down. Am I missing something? Can I even use the spool that I have? Is there a better way to do this without a spool? The original design had gate valves, I would do that again, if I knew how it went.....Any thoughts?
