Tool for hyd. coupling
/ Tool for hyd. coupling #1
beenthere
Super Star Member
Southern Wisconsin, USA
JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
Have modified a ViceGrip pliers (model 8R) to aid in sliding female coupler sleeve back for ease of engaging male component.
With unsecured couplings on dual hoses running from rear 3rd SCV to grapple thumb on FEL forks, difficult to slide the sleeve back while pushing the male into the female coupling.
Decided to try modifying the VG pliers designed with flats for sheet metal work, by filing out the flats to just fit the female coupling so closing the pliers to "lock" allows holding it in the open position to engage the male end. This fits the 1/4" Pioneer coupling.
/ Tool for hyd. coupling #2
Sometimes I have a difficult time connecting the two because of too much pressure in the lines. I know I have seen a tool to press the end button to release the pressure too. Good job making a tool to help your work go easier.
/ Tool for hyd. coupling #3
When pressure is in the line, I just push the QD ball into the nearest clean surface. A little messy, but I have paper towels ready to wipe everything off.
hugs, Brandi
/ Tool for hyd. coupling #4
Besides relieving pressure, make sure you are using your other hand to push in on the male end as you squeeze the pliers.
I've not found a tool to press in on that end button, but have wondered about making something. Presently I have a dummy female connector that I leave on the male coupling of one of the FEL loader lines. It has a plug in the hose end that I can loosen if there is pressure in the line (and usually is the case in the spring after the FEL sits over the winter while the snowplow is in its place).
But now you've given me the thought that the other side of this ViceGrip tool maybe be able to use that tool to also release pressure. Will look into that.. prolly today yet.. :)
/ Tool for hyd. coupling #6
Plenty spendy for the Amazon linked one.. better price for the Farm Show mag.
Googled and saw some YouTube's about some other ideas, one intrigued me was this link
Dave's Delights Hydraulic Hose Pressure Relief - YouTube
Here is a pic of the one I hang on my FEL while it is in storage.. then just back off the plug and be wary of oil coming out at the moment..
I think some modification of a channel lock pliers with some shielding to limit oil spray from the tip would work pretty well too..
/ Tool for hyd. coupling #8
I just tap the ball with a piece of wood. I've had to use a dowel or unsharpened pencil a couple of times for the one in the female coupler.
/ Tool for hyd. coupling #9
Always one around, hangs nicely on the tractor doesn't cause damage... Like a screwdriver would.
Wrap it in a rag, push it or tap if necessary.
/ Tool for hyd. coupling #10
For my grapple (two male connectors) I installed two female connectors to the lid of a 5 gallon bucket. When I remove the grapple I connect the lines to the bucket. The lines can not build any pressure and are easy to reconnect.
I considered making a vise-grip tool with a fork to hold the connector and the other end to push the poppet or ball in. I was going to use the "C" clamp type vise-grips. I worried about oil spraying in every direction so never built one.
/ Tool for hyd. coupling #11
I put my female QDs on brackets on the loader and the males on the grapple hoses. I put color coded ty wraps on both male and female QDs so I won't get them swapped. Before I remove the grapple, I close the "lids". Before I reconnect the grapple, I press the diverter button on my joystick and cycle the grapple control with just the key on. That bleeds any remaining pressure from the valve to the female QDs. Only time I have to press the ball on the male QD is when I remove the grapple with the lids open. Which I only did once.
hugs, Brandi
/ Tool for hyd. coupling #12
In all my years here - only needed two hoses made up. Unscrewed one fitting on the tractor - took to House of Hose - they made up the two hoses with the correct fittings.
/ Tool for hyd. coupling #13
hugs, Brandi
It was temperature change, not leaving the grapple open that caused me trouble. I always close the grapple when not in use, on or off the tractor.
/ Tool for hyd. coupling #14
Like others, I just take a flat punch, or a piece of wood, stick it agains the ball, wrap a rag around it to control and splash that may occur, and hit it with a hammer. A drop or two of oil will come out, and that's all it takes to relieve the pressure. Works on both male and female connectors.
I think I learned that about 17 years ago here on TBN. I think it was Bird that told me how to relieve the pressure that way VS me cracking the fitting threads with a wrench.
Thanks, Bird! :D
/ Tool for hyd. coupling #15
just turn the tractor off a quick forward and backward of the lever just a little past the center each way before you disconnect will take the pressure off the lines. like others have suggested always put the cylinder of the implement in a non pressure situation.
/ Tool for hyd. coupling #16
When left open, gravity also pulls the lids down, adding pressure on the fittings.
hugs, Brandi
/ Tool for hyd. coupling #18
I use a simple manifold for all my hydraulic implements.
Any built up pressure is relieved by using the valve to drain excess oil into a container
/ Tool for hyd. coupling #19
hugs, Brandi
Agreed. For safety, I always close mine before removal.
I leave the dual lids up because I store my grapple outside. I use two 2x4s to prop them open so gravity doesn't close them.
Don't have a picture of the props from the front, but you can see the bottom of them from the back:
/ Tool for hyd. coupling #20
I added a “T” to each line of my flat face coupling lines on the attachment that have hydraulic hoses. From the “T” I ran a short hose with ag fitting on the end. Now I just grab the hose and tape the ball on the ag fitting against the attachment and it lets off the pressure.
Fast and easy when your swapping tools several times a day. Watch your eyes and yes it does leave a little bit of oil on your attachment.
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
Fendt FT900 Front Fenders (A63117)
Fendt FT900 Front...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2018 BOBCAT T740 SKID STEER (A64279)
2018 BOBCAT T740...
2003 FORD F-250 XLT SUPER DUTY CREW CAB TRUCK (A64280)
2003 FORD F-250...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
