brandon5110
Having major problems with hydraulics. I have a service manual but not getting enough info from it. What is a good manual.
Started having problems with pto not working after i hit the tranny filter on somethen and knocked it off while i was bailing.. Got it fixed filled up with fluid and wouldnt work very well. But could run brush hog and it started to work good. Nxt time i bailed i turned 4 bails then started slipping. Very worked again. Then started noticing steering resistance while lowering the loader. Started looking where to start. Then nxt time i used tractor i lost nearly all hydraulics. But if i move a remote lever i would get some back. Then i could mover loader and 3pt. But steering was ok not the best. Brakes worked fine. Need some help thanks
