john deere 2555 hydraulic problems
   / john deere 2555 hydraulic problems #11
Ok well i checked screen and it wasent to bad. Alot of fine metal in tranny filter. No chuncks
That is really, really bad....................................... That fine metal is probably from friction material, often the brake pads being rotted off and metal to metal contact. A ruined pto clutch/brake or ruined high/low planetary set will also do that.
The wrong oil or water contaminated oil will crumble the clutch and brake friction material to bits.
How long have you owned the tractor and how many hours have you put on it?
Ive had it bout a yr. I pretty sure breaks r bad. No water in oil. I might have put 20 yrs on it sence i owned it. First time i changed filter there was fine metal in filter. But didnt think to much of it cuz the way it was taken care of. But when i took it off yesterday. There was bout the same amount in there and its only been 6 months sence i changed filter. Not alot of yrs sence then.
   / john deere 2555 hydraulic problems #13
brandon5110
Does your tractor have hyd hi-lo? If so try operating hyd's in both speeds of hi-lo. With engine at operating temp,3 pt fully raised look inside hyd filler hole for spraying hyd oil. Also remove FEL return hose from tractor,aim return hose in hyd filler hole and with ""FEL valve in neutral"" no oil should exit hose with engine running.
Ok dosent have hi and lo. I will try that with fel when get oil filter and everthing ready. Will let u know.
   / john deere 2555 hydraulic problems #15
I think you need to consider R&R of rear axles to check brake linings before hyd's get a lot worse.
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
2021 SELLICK S80 STRAIGHT MAST FORKLIFT (A51242)
2021 SELLICK S80...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
2020 Hisun 750 CCEFI UTV (A50514)
2020 Hisun 750...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
