Yea, the axles are not vented, when you open the plug you hear the air venting. ( in or out...) This started in the winter when it was cold, still not sure how a seal can go bad unless something is worn, and with 500 hours I can't imagine that is the case.
So, DFKRUG, if you see this, to just replace the lower seal on the front axle looks easy, take off the wheel, remove bolts, and the entire thing comes apart. One snap ring and it should slide out... How hard can this be.....
Kenny: 40k for a new cab machine with 37HP is a bit much, looks like we can get a 50 HP cab machine for almost the same $$!!!!
regards
Wayne
