sbeckwith
Member
- Joined
- Jul 10, 2011
- Messages
- 29
- Tractor
- John Deere 4720, Kubota L3830, John Deere 2355 MFWD, John Deere 4430, Case 1030, John Deere B, John Deere 730D, Hustler SD60
Good Day All,
I am having an issue where the 20 amp fuse that sends power to the key switch blows intermittently. When it does blow, the tractor keeps running, lights still work, etc. The instrument cluster stops working and when the tractor is shut off, the key switch no longer supplies power to crank the tractor over to start the tractor up. Replacing the fuse allows it to start again and it may or not blow again the next time the tractor it used. I suspect there is a wire that is shorting while out in the field bouncing around, but I have no clue as to which wires draw power from that fuse. Is there anyone who may have access to an electrical diagram in order to figure out which wires to look at?
Details:
Fuse does not blow when starting the tractor
Fuse does not blow every time I use the tractor around the farm
Fuse blowing does not cause tractor to stop running
Fuse blowing does not cause running lights to stop working
Fuse is located in position #8 on the circuit board
Make: JOHN DEERE
Model : 2355 MFWD Cab Tractor
Year: 1998
Hours: 5562
Serial Number: L02355V632762
Thanks in advance for your help !
Steve
Details:
Make: JOHN DEERE
Year: 1998
Hours: 5562
Steve
