dkair
Member
The goal of this post is to get my questions answered and, more importantly, get more of the Kioti wiring documented with pictures. I am also more than happy to answer any questions I can about the project. My apologies if my search skills failed me and all of this is already documented.
I am working to add 3 LED work lights to my CK35 HST (2013). From reading previous posts, I thought I had my wiring figured out. However, as I got down to it tonight I am not quite sure. I already have two incandescent work lights on either side of the SMV sign that were installed by the dealer. Each plugs into bullet style connectors. I thought the right one was on the "Customer Use" circuit, but that proved to be untrue. Here's what I found.
27 Watt, 1550 Lumen TUFF LED Lights purchased from Amazon on custom made bar held on to ROPS with U bolts. The lights were a good price purchased in a set of four (the fourth is going on my ATV) and the quality seems quite nice.
My fuse layout
The light on the right of the sign plugs into right most bullet connector. It has power when the key is on. It is connected to the "Back Up Lamp, Working Lamp" 7.5A fuse.
The light on the left of the sign plugs into left-side bullet connector. It has power when the headlights are on. It is connected to the "Head Lamp, Tail Lamp" 7.5A fuse, but remains on if I pull the 20A "Headlight, Horn" fuse. Out of curiosity, does anyone know why there are two fuses for the headlights? If you pull either fuse, both headlights go out.
This connector doesn't seem to have any voltage under any scenario - does anyone know what it is?
Is this the "Customer Use" connection and, if not, what is it? Located further back than the two bullet connector pairs.
Does anyone know what this connector is for? Located on right side near right side work light bullet connectors.
Thanks as always for any help,
DK
My fuse layout
DK
