k0ua
Epic Contributor
I wonder if the NX series, has it's charge pump for the hydrostatic transmission from the steering section flow. This is the way DK series works. There is no charge pump in the transmission, the charge pump function gets its fluid after the steering valve gets done with it then on to the oil cooler by the radiator, the hydrostat filter then into the hydrostat transmission. I am not sure where they tapped in for the DO3 valve for the 3rd function, but I would think it would be after the loaders PB connection and heading to the other selective control valves. This is fed from the larger section of the main hydraulic pump. Not the steering section. I am also having trouble understanding this. Other than the heat buildup. Of course the NX may not be the same as the DK either.
