Bsavulis
Member
I built a grapple for my CK25, while accessing the hydraulic lines in the torque tube of the loader to connect up a diverter valve I found a mouse nest. Further inspection revealed that the tee fittings were all rusted and needing replacement. You can see the nest and the fittings in the photos below. I pulled the hoses out of the arms the cross tube. Cleaned everything up and that is when I found the cracks. I know this was an issue a decade ago, where the KL130 loaders were cracking at the torque tube inspection plate corners. The tractor has the repair kit that was designed to prevent this very thing. I have a feeling it loosened up over use or the unit was never installed properly. So I am looking for advice, drill the ends of the cracks and tig weld, add more steel, leave it alone?
When the kits came out it was a mandatory dealer install. Since so much time has passed the installation instructions must be in the public domain by now. Can someone point me towards the info. BTW it is an 2005 CK25HST with 600hrs.View attachment 596231
