quick attach bent
   / quick attach bent #11
Let us know how it goes :thumbsup:
   / quick attach bent
The metal on this one looks ALOT heavier than the other threads, however, I will try a few things and post an update in a couple days. Thanks for the replies...
   / quick attach bent
Looks like we're back in business. push and pulled a bit with a porta power. springback was a lot so the final straw was done on a tree. It is not perfect but the surfaces line up enough to fit the bucket back on. thanks for the suggestions!!
   / quick attach bent #14
:thumbsup:
   / quick attach bent #15
This thread just helped me fix mine. Only took 60 seconds using the tree method and you can't even tell the bar was bent.
   / quick attach bent #16
:thumbsup:
   / quick attach bent #17
I was grappling today and twisted my speader bar. I was thinking it would need to be cut and rewelded. But before I go to my Grand daughter's birthday party later today, I'll try the tree method.
hugs, Brandi
   / quick attach bent #18
I'm glad for you guys not having all the trees cleared yet that you can bend back your plates again.
   / quick attach bent #19
I bumped it into a tree yesterday morning and adjusted it some. But still have an inch to go to get the grapple's right latch down and locked. I can latch onto my bucket, but nothing else.
Seems at full curl,there is movement and the grapple shifts forward on the right side, so I am thinking I have a bent pin. So I am will be ordering 4 new pins. They are all the same size. The right plate of the carrier is twisted forward at the top about an inch. It is, looking straight down, tweeked a little there also, so it doesn't slide into the V on the attachment enough.
So, if I can get a new carrier, I will. Either that or pay the welding shop and not have any idea if everything I have will install and latch.
hugs, Brandi
   / quick attach bent #20
Bumping doesn't sound good, use the hydraulics to twist it back. Remove the grapple, at full dump you should see a gap on one side:
Curl up a little, put a small shim on the other side and full dump to twist it back straight:
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A57024)
2022 Brush Wolf...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Rooster Weathervane (A55853)
Rooster...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A57193)
UNUSED WOLVERINE...
UNUSED LANDHERO LDH-SP12 12 TON PRESS MACHINE (A57193)
UNUSED LANDHERO...
