OEM Mahindra hydraulic Filter? How do I know that this filter is genuine?
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #1
1acre
Mahindra 2615
I just bought some filters for my 2615. They were advertised as Genuine Mahindra filters. Are they supposed to say "Mahindra" on them? None of mine do. The hydraulic filter is just plain black with the part number on it. Is that what the real filter looks like?
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #2
Did you get them from a dealer or off some random web site , vendor
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #3
If it's under warranty. I would recommend the OEM filters.
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #4
I have a Mahindra 1526. Which I think is about the same. Mines just newer. My filters are solid black also. The hydraulic filter part number is 19642509000. The part number for the HST transmission Is 19682581000. The boxes are solid white with a white and red them. That say Mitsubishi genuine parts on them. 1580497231632.jpeg
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #5
Just checked both hydraulic filters on my 2615. Both are black with part numbers only. These filters are used on other brands of tractors, too. If you have the correct part numbers, don't worry. To be sure, compare gaskets.
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #6
Plus one for the OEM filters, specially the hydraulic ones.
It's very common for various brands to burn hydraulic pumps or have poor performance on the hydraulic because the owners bought aftermarket filters that looked the same on the outside but internally are setup differently than the OEM, causing the pumps to starve for oil.
I have a Mahindra 1526. Which I think is about the same. Mines just newer. My filters are solid black also. The hydraulic filter part number is 19642509000. The part number for the HST transmission Is 19682581000. The boxes are solid white with a white and red them. That say Mitsubishi genuine parts on them.View attachment 639487
Same filter as mine. Thanks for the pic. I guess I have nothing to worry about:thumbsup:
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #8
Those are the OEM filters in the photo.
My dealer recommended the OEM HST filter since it sees higher pressures. Some of the aftermarket filters fit but may not be designed for the high pressures. The other filters have cross references to the common brands- Wix, Donaldson etc. Their are a few threads in here that should list them.
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2017 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2017 GENIE GS-1930...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
