Massey Compact owners: hydraulic system maintenance
   / Massey Compact owners: hydraulic system maintenance #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Some folks might not be aware of the cleanable, metal-mesh hydraulic filters underneath the tractor. These need to be removed and cleaned. I believe the first cleaning is required at 150 hrs.
They are definitely not as convenient to service as typical spin on canisters, but then again, no extra cost is required either. I'm not sure if Massey/Iseki is the only Mfg that uses this design, but I know at least Kubota, Kioti, and LS use traditional spin on filters for general hydraulic and HST filtering. Not sure if it is an advantage or disadvantage... Just make sure you service them.
If you have a HST model, you will also have an additional spin on bypass filter, only $13 from NAPA for that one.
Pics:
   / Massey Compact owners: hydraulic system maintenance #2
My 1526 has the same set up. When I did my 50 hour maintenance last winter I removed and cleaned the mesh filter and replaced the cannister.
I tried to find a local source for the spin on cannister filter so as to avoid the drive to the nearest MF dealer, but had no luck. I was told that maybe once the particular filter that my 1526 uses has been out for a bit, maybe there'd be an aftermarket part for it.
   / Massey Compact owners: hydraulic system maintenance #3
Good find, I'm going to have to check mine. I don't recall this in my owners manual, but I have noticed one difference between it and the tractor.
   / Massey Compact owners: hydraulic system maintenance #4
TSO - pray tell that NAPA part number for the hydrostat spin-on filter. I want to check if it'll work on my 1754. Pretty please?
These are my notes on my 1652:
Engine oil, 10w-30, or 5w40, 8.5 qts, 3/4 drain bolt.
-Coolant: 8 Qts (7.6L)
-Hydraulic oil, Permatran III, 7/8" drain bolt, 8.2 gal.
-Front axle Permatran III, 6.2 qts, 11/16 bolt.
Oil filter:
Mobil 1 #M1-102
AGCO #3757038M2
ISEKI #6213-240-005-1
DENSO #115010-5250
NAPA #1348
Hydraulic filter:
AGCO #3608996m91
Napa #1664 ($13)
Fleetguard #HF28850
Donaldson #P556005
Wix #51664
Still working on a cheaper source for air filters (engine and cabin)
   / Massey Compact owners: hydraulic system maintenance #7
I found that in order to remove the mesh suction filter on my 1734E the frame rail for the loader had to be removed first. The filter can not be pulled all of the way out with the rail in place. I assume it is the same on the 1725E and 1739E.
Thanks also for the filter numbers, I will need to cross check the agco numbers for mine. Their prices are a whole lot higher than $13!
   / Massey Compact owners: hydraulic system maintenance #8
The spin-on canister hydraulic filter for my 1529 was $179!
NAPA has no cross reference yet...
Going to look for the metal sump filter though...thanks for posting that!
   / Massey Compact owners: hydraulic system maintenance #9
Ouch, I thought I got robbed at $79 from my dealer. At least that's what I believe I paid, but I'm sure it wasn't $179.
   / Massey Compact owners: hydraulic system maintenance #10
The hydrostat filter for my rig was $79. The AGCO number 7069738M1 doesn't match, or even resemble, what TSO reported, though. I'll have to see if I can find dimensions for NAPA filters to compare with my used one that I kept for just such a purpose.
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
Ran during check in. No longer running. (A51694)
Ran during check...
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
1987 Ford 2110 Tractor (A50514)
1987 Ford 2110...
2009 Honda Pilot AWD SUV (A50324)
2009 Honda Pilot...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
