3-Point Hitch Tractor Three Point Hitch CROSS-DRAWBARS
   / Tractor Three Point Hitch CROSS-DRAWBARS #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Unlike a tractor rear/center drawbar, Photo #8, which is attached directly to the tractor frame/chassis, a tractor cross-drawbar, Photo #1, mounts through the "bullseyes" integral to the left and right Lower Links of the Three Point Hitch. An inexpensive fitting, known as a drawbar lock, Photo #2, couples the cross-drawbar and one Lower Link to prevent the cross-drawbar from twisting/turning on its axis. Alternately to a drawbar lock, a substantial vertical component, Photos #3 - #6, is bolted to the cross drawbar, adding a Top Link connection and a receiver hitch at the base. A third option is an integrated, triangulated cross-drawbar, Photo #7, which includes a Top Link connection. Option three is the high value hardware.
A cross-drawbar allows elevation of towed logs, trees or railroad ties using Three Point Hitch hydraulic power. With 4" to 6" of elevation loads towed on the ground are unlikely to encounter obstructions stall the tractor or, much worse, drive the tractor vertical if the operator in not alert.
(I once had a Deere 750 vertical, towing timbers from the rear/center drawbar.)
With logs and trees elevated, less of the load is in ground contact, decreasing friction of the load against the ground and preventing the dragged load from plowing dirt. In some circumstances elevation permits heavier loads to be pulled.
The disadvantage of a cross-drawbar is its integration with the Three Point Hitch, a weaker connection point than the tractor frame/chassis. In imprudent operator could damage the Three Point Hitch with imprudent loads or imprudent operation. With loads in shear to a 20" to 30" cross-drawbar substantial strain is placed on perforated, mild steel bar. Most cross-drawbars in use for some time show distortion but remain functional; mine included.
Cross-drawbar loads pulled with load center-of-mass above rear axle height may induce tractor instability. My L3560 compact tractor is heavy for its size and my loads prudent. Tractor instability due to a moderately elevated load has never been an issue in my experience.
Using a Cross-drawbar to pull or push a two wheeled cart or two wheeled implement can be dangerous. The Three Point Hitch does not include a latch to prevent instantaneous Lower Links and cross-drawbar rise, potentially upsetting the load and injuring assistant(s). Hazardous rise may occur as a cart is loaded or unloaded, as cart load is moved in forward or reverse, or if someone steps on rear of the load, shifting weight distribution to the rear.
You will find reference to using chains or such to limit vertical movement of Lower Links for such loads.
[Credit: KTHOMPSON
Cross-drawbars are readily available, sized for Category 1 and Category 2 Three Point Hitches in various widths. Cross-drawbars accept accessory clevis and bolt-on installations. Several are visible in photos.
The advantage of the rear/center drawbar, Photo #8, is its fixed attachment to the tractor frame/chassis, the strongest connection possible. On my Kubota L3560 the rear/center drawbar is always in place. The rear/center drawbar does not interferes with Three Point Hitch implements nor the mounted cross-drawbar.
Photo #3 ~ Omni Mfg., LLC, Deerwood, MN Combo Draw Bar Trailer vertical component. (2/2012)
LINK: Combo Hitches - OMNI Mfg LLC
Photo #4 ~ Triangle Hitch
LINK: 3 point hitch drawbar in Heavy Equipment, Parts & Attachments | eBay
Google Images: tractor cross drawbar - Google Search
ROPS folded because I was working in Florida jungle, rife with vines.
   / Tractor Three Point Hitch CROSS-DRAWBARS #2
You did a decent job I think but think some other points are needed. Using the "cross drawbar" (never heard them called that but terms makes sense. Only heard "lift arm" drawbar.) can be dangerous with load on wheels. That includes trailers or wheeled implements. The lift arms do not have the ability to prevent drawbar from raising in a split second. This can happen as a trailer is loaded or unload, as load is moved or even a person walking from from of trailer to the rear or stepping on rear of trailer. This sudden tilting action can cause a person to loose balance, major issue backing a trailer as it or load can dig into the dirt, or load being damaged or lost and even damage to the lift and trailer.
You will find reference to using chains or such to limit vertical movement for such loads.
One other issue with that drawbar is often you will want to pull the typical pin hitch trailer or implement as so quick to use and easy as you can use the lift to come to the hitch level rather than just jack to raise or lower the implement hitch to adjust to fixed drawbar. The issue is a tractor can make rather sharp turns and so easy to turn sharp enough putting the hitch in a bind bending and damaging the trailer or implement hitch.
Totally agree with pulling such as logs lifting the towed end is a great advantage just want the tractor stability for rearing up. Do not try jerking a load to move it will lift raised as damage to the lift is possible but picking front end clear and lose of such as steering and maybe rear roll over is possible. But using sense and paying careful attention the lifting of the load for drug items can be a great help.
As to bent drawbars, have only even seen that happen by wrapping a chain around drawbar without use of clevis and the drawbar rotates so the flat side is vertically and not horizon as it is designed to be used. For years I seldom saw a fixed drawbar used but once I began using implements on wheels pulled by fix drawbar hardly ever use the cross drawbar. The fixed drawbar is much more stable as it prevents shifting. But if pulling logs or trees, it will be what I use to pick the load so it does not dig into the dirt.
Tractor great tools with all the options they have such as the fixed and lift arm drawbar option. Reason paying attention and thinking is so important to keep tractor and load important but much more important the operator and anyone around safe.
   / Tractor Three Point Hitch CROSS-DRAWBARS #3
I would add to that: And knowing when a bigger tractor would be the right tool for the job.
Sure, most of us have gotten away with doing big jobs with small tractors over the years, but common sense should always prevail.....
   / Tractor Three Point Hitch CROSS-DRAWBARS #4
Jeff,
Can you rotate your smiling cross drawbar 180 degrees (upside down for a frown) then use it/abuse it like you did before to straighten it?
Yep, as mentioned, if pulling a trailer with a cross draw bar, you want a LOT of extra tongue weight so 3 pth doesn't pop up. And don't forget about that when shifting load when unloading; or when you're backing up and 3 pth can pop up if trailer tires encounter an obstacle.
Today is a tractor maintenance day. I may reverse the cross-drawbar today, along with blowing mower debris off the tractor, fueling and greasing. I will have my tools handy.
And knowing when a HEAVIER tractor WITH GREATER INERTIA would be the right tool for the job.
Sorry, I could not resist.
   / Tractor Three Point Hitch CROSS-DRAWBARS #7
Some set-up use hard links from the drawbar to the top link connector on the tractor.
For many many years growing up we used this type of draw bar on our 8N till we finally added the frame mounted drawbar kit.
Here's a "borrowed" image from the web similar to what we had. 3pt lift arms, anti-sway bars, and "anti-lift bars" (Ours is/was bent more. :D )
Another thing to be noted for the novice, if you are using a drop pin style hitch instead of a ball hitch you should NOT use the drawbar lock. Drop pin style hitches lack the ability to rotate up & down when traversing hilly terrain like a ball hitch can. Thus the Inherent ability for the bar to rotate in the lift arms is required.
   / Tractor Three Point Hitch CROSS-DRAWBARS #8
The major problem with the lift arm drawbars is they are strong (sort of) in one direction but weak in the other direction.
   / Tractor Three Point Hitch CROSS-DRAWBARS #9
Sheepishly raising hand and alluding that I may have first hand knowledge of such a thing.
With loads perpendicular to a 20" to 30" cross-drawbar substantial strain is placed on perforated, mild steel bar. Most cross-drawbars in use for some time show distortion but remain functional; mine included.
I speculate mild steel is used for cross-drawbars so they bend, gently, rather than fail catastrophically under a heavy load.
Cross-drawbar Caution: The Three Point Hitch relies on "tongue weight" (mass of the load bearing down on the Lower Links) for vertical stability. The Three Point Hitch does not include a latch to prevent unanticipated upward movement of the Lower Links, cross-drawbar and wheeled load.
Reversal of tongue weight may occur as cart load is pulled up a slope, over uneven ground, if a cart is inadvisedly loaded at the rear first rather than the front or center first, or if someone steps on rear of the load, shifting weight distribution to the rear. Caution with two-wheeled drawn implements is also advised, for identical reasons. The potential for load upset, tractor upset and human injury is there.
Will someone please contribute a thread reference here? I have no experience restraining Lower Links in my woods work over flat Foriida land.
"You will find reference to using chains or such to limit vertical movement of Lower Links for such loads."
Factors that cause a tractor to tip over backward include the load and height of the hitch from the ground.
Positionng Lower Links and cross-drawbar above rear axle height may cause a tractor or the drawn load to tip over backward. Any time you are pulling a load with a tractor, the load is trying to pull the tractor over backward, especially when moving up a slope, when load is lower on the slope than the tractor. The tractor tries to pivot around the point where the rear wheels touch the ground. The Three Point Hitch does not include a latch to prevent unanticipated upward movement of the Lower Links, cross-drawbar and tongue of wheeled load.
Any time you pull a load with a tractor, the load is trying to pull the tractor over backward. The Three Point Hitch relies on "tongue weight" (mass of the load bearing down on the Lower Links) for vertical stability. The Three Point Hitch does not include a latch to prevent unanticipated upward movement of the Lower Links, cross-drawbar and wheeled load.
The Three Point Hitch and optional cross-drawbar are designed to pull heavy loads at or below rear axle height, over level ground, with minuscule risk of a backward upset. When the cross drawbar is raised, the chance of a backward upset increases. Always position Lower Links and cross-drawbar at the level of the rear axle or as low as conditions permit.
Extra hazard exists as a loaded cart is pulled up a slope, over uneven ground, if a cart is inadvisedly loaded at the rear first rather than the front or center first, or if someone steps on rear of the load, shifting weight distribution to the rear. Caution with two-wheeled drawn implements is advised, for identical reasons.
[Subject credit: KTHOMPSON]
Cross-drawbars are readily available in 20" width for subcompact tractor, 26" width for Category 1 compact tractors and 38" width for Category 2 tractors. Cross-drawbars accept accessory clevis and bolt-on installations. Several attachments are visible in photos.
Working Draft 1.1
CROSS-DRAWBAR Screen Shot 2018-10-18 at 5.06.48 AM.png CROSS-DRAWBAR​
A tractor cross-drawbar mounts through the "bullseyes" integral to the left and right Lower Links of the Three Point Hitch then secured with lynch pins. An inexpensive fitting, known as a drawbar lock, Photo #1, couples the cross-drawbar and one Lower Link to prevent the cross-drawbar from twisting/turning on its axis. Alternately to a drawbar lock, a substantial vertical component, Photo #2, is bolted to the cross drawbar, adding a Top Link connection and a receiver hitch at the base. A third option is an integrated, triangulated cross-drawbar, Photo #3, which includes a Top Link connection. Option three is the high value hardware.
Cross-drawbars are readily available in 20" width for subcompact tractor, 26" width for Category 1 compact tractors and 38" width for Category 2 tractors. Cross-drawbars accept accessory clevis and bolt-on installations. Several attachments are visible in photos. Mild steel is used for cross-drawbars so they bend, gently, rather than fail catastrophically under a heavy load.
A cross-drawbar allows elevation of pulled loads using Three Point Hitch hydraulic power. With 4" to 6" of elevation loads are unlikely to encounter obstructions either stopping the tractor or driving the tractor vertical if the operator in not alert.
With loads elevated less of the load is in ground contact, decreasing friction of the load against the ground and preventing the load from plowing dirt. In some circumstances elevation permits heavier loads to be pulled.
Photos #4 - #6.
The disadvantage of a cross-drawbar is its integration with the Three Point Hitch, a weaker connection point than the tractor frame/chassis. An imprudent operator could damage the Three Point Hitch with imprudent loads or imprudent operation. With loads perpendicular to a cross-drawbar substantial strain is placed on perforated, mild steel bar. Most cross-drawbars in use for some time show distortion but remain functional; mine included, Photo #2.
Any time you are pulling a load with a tractor, the load is trying to pull the tractor over backward. The Three Point Hitch relies on "tongue weight" (mass of the load bearing down on the Lower Links) for vertical stability. The Three Point Hitch does not include a latch to prevent unanticipated upward movement of the Lower Links, cross-drawbar and a wheeled load. Photo #7.
Sudden reversal of tongue weight may occur as cart load is pulled up a slope, over uneven ground, if a cart is inadvisedly loaded at the rear first rather than the front or center first, or if someone steps on rear of the load, shifting weight distribution to the rear. Caution with two-wheeled drawn implements is also advised, for identical reasons. The potential for load upset, tractor upset and human injury is there.
The Three Point Hitch and optional cross-drawbar are designed to pull heavy loads at or below rear axle height, over level ground, with minuscule risk of a backward upset. When the cross drawbar is raised above rear axle height, the potential for a backward upset increases. Always position Lower Links and cross-drawbar at the level of the rear axle or as low as conditions permit.
REAR/CENTER DRAWBAR DSC00514.JPG REAR/CENTER DRAWBAR​
Integral to the tractor is a rear/center drawbar which is attached directly to the tractor frame/chassis. Rear/center drawbar does not elevate; it is fixed. Rear/center drawbar in photo has a clevis mount chain grab hook attached, a ubiquitous fitting. (Rear/center drawbar is often a new tractor factory option on lighter tractors.)
The advantage of the rear/center drawbar is its fixed attachment to the tractor frame/chassis, the strongest connection possible. On my kubota L3560 the rear/center drawbar is always in place. The rear/center drawbar does not interferes with Three Point Hitch implements nor the mounted cross-drawbar.
If you must pull a cart or two wheeled implement over uneven ground or up a slope, bolt on appropriate size hitch-ball to the fixed rear/center drawbar.
Photo #2 ~ Omni Mfg., LLC, Deerwood, MN Combo Draw Bar Trailer vertical component. (2/2012)
Photo #3 ~ Triangle Cross-Drawbar Hitch
LINKS (2): 3 point hitch drawbar in Heavy Equipment, Parts & Attachments | eBay
Tractor 3 Point Hitch Adapter, tractor hitch adapter
Google Images: TRACTOR cross drawbar - Google Search
   / Tractor Three Point Hitch CROSS-DRAWBARS #15
Ask and you shall receive ...
Re: Tractor Three Point Hitch CROSS-DRAWBARS
Living on land that has some very steep slopes and having the load slide back while climbing one of those slopes caused an increase in drag, coupled with a reduction in traction as the rear of the trailer started dragging and the drawbar went from pushing down thru the 3pt to lifting thru the 3pt. The resulting loss of traction caused me to spin all 4 wheels as I tried to climb up the hill and the dropped rear of the trailer dug in deeper when I tried to back down the hill. I was stuck. With a steep drop off to the left and a steep up-slope to the right, turning wasn't an option, either. I was stuck, but good. I put the brakes on, placed a log behind the rear tractor tires (unless I'm on level ground I don't trust the parking brake, especially when the trailer is trying to lift the rear axle). Convinced that the tractor-trailer combination was adequately immobilized, I climbed into the trailer and moved the load forward until the rear of the trailer lifted off the ground and the 3pt dropped back down. I was then able to climb out of the holler and back up to the level field. I chained the hitch (pictured) to keep the hitch from lifting, should the load ever shift again. It does this very effectively. What it doesn't do is change the lifting force applied to the 3pt by the trailer when the load shifts aft, which reduces traction (and braking). As a former truck driver, I am ashamed to admit that I was guilty of the basic offense of "Failure to Secure the Load". More attention to trailer load management & less reliance on hitch band aids are my take aways from the experience.
-Jim
   / Tractor Three Point Hitch CROSS-DRAWBARS #16
Interesting inverse concept to check chains...
577315d1541260061t-tractor-three-point-hitch-cross-3ph-locked-jpg
Never quit thought of imbalance causing 3PH to rise without some sort of restraint...
Dale
   / Tractor Three Point Hitch CROSS-DRAWBARS #17
Glad I ran across this older thread. Jeff 9366 took time to try to save others unaware of this very serious problem. And Baby Grand helped verify how quickly it can happen. A seemingly routine task can turn into injury or death before we can do anything fast enough to prevent it. Any new tractor owners need to heed these guys advice so as not to become a statistic. Not all tractor deaths are rollovers as we all know. As a Rural Fireman for many years I witnessed this firsthand. Three accidents came to mind. All were Local. All had tractors and experienced owner/operators. The same scenario in all three was they were pulling bigger/heavier loads than the tractor could handle. So after repeatedly spinning out each one decided maybe moving the chain up higher on the tractor would help get better traction by pulling down a bit. A deadly decision. So reread Jeff9366 and Baby Grands posts as it could save you or a family injury or death. Thanks for your informative posts guys. Have a safe Spring, and pull with your drawbar on heavy loads if possible. Earl
MAX-24-Dean - 7/1/2022​
Mahindra MAX24
Max 26 Trailer Towing Capacity from 3 pt quick-hitch with ball mount.
I tow from the drawbar only, not the 3 point hitch.
I used the 1200 lbs. lift capacity on the three point hitch of my Max 24 to give me a ballpark value for safety. Used this value as what the brakes on the tractor can handle as extra load.
I tow a 4 wheel trailer with spead axles, so only the weight of the tongue is on the drawbar hitch. Tongue hitch weighs somewere in the 12 lb. range.
On level ground I have loaded it with 30 one hundred pound bales. does fine on level ground.
Max load going down the gravel drive with 9 percent slope has been 10 bales (so 10x100=1000 lb.s + trailer weight of 300 lbs. for total weight of 1300 lbs.) Wouldn't want to have much more weight than that going downhill
When I was 11 years old, I saw an accident where the tractor tipped over backwards onto a loaded single axle trailer that was connected to the 3 point hitch. It wasn't a sight I wanted to see at that age.
Please don't consider pulling any object with the 3 point hitch unless it is designed for ground engagement.
   / Tractor Three Point Hitch CROSS-DRAWBARS #19
I just pulled down an old 36’ wide x 46’ long x 16’ wall barn, that my great great grandad had built in 1883, using the cross drawbar hitch on my JD 4120. I used a 1/2” wire rope thru a snatch block, attached to a big tree on the other end to double my pull.
It dropped very easy, with the tractor in the lowest gear. The cleanup is going to take me a while. 4 layers of tar shingles on top of two layers of cedar. The chestnut roofing boards and oak rafters under that is in pretty good shape. I am going to use that, and some of the 6” and 9” square hand-hewn posts and beams to build a big woodshed on the back of my new pole barn.
I would have liked to save that old barn, and another twin to it that I dropped a couple years ago to make room for my new pole barn, but the roofs and foundations were shot.
2002 International 9200i Truck (A61306)
2002 International...
UNUSED FUTURE P45-56" HYD MINI BREAKER HAMMER (A60432)
UNUSED FUTURE...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
2022 Ram 2500 (A55973)
